Questions About Buying Takeoffs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffreyB, Dec 13, 2015.
  1. Dec 14, 2015 at 10:40 AM
    Mariotaco
    Mariotaco Well-Known Member
    Mario
    El Paso, Texas
    11 SR5 4x4
    I have the steel sensors on the same alloy wheels.. They were installed backwards and have lasted without issues for about a year or so. I was told by the guy installing them that when they take off the tire from the rim I need to tell them to be careful around the area where the sensor is at because if they put the machine that takes the tires off the rim it will break the sensors.
  2. Dec 14, 2015 at 11:06 AM
    Pigpen
    Dan
    Northwest Montana
    The mount/ dismount machine will break the sensors right off. I would only allow a highly trusted tech do this for me. I would recommend running without sensors rather than putting them in the alloys. You're in Montana -you should have two sets of wheels (summer/ winter) anyway.
  3. Dec 14, 2015 at 3:58 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Would also make installing and removing the tire tricky.
  4. Dec 14, 2015 at 4:14 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Yea, that's pretty good and I would grab them. I've seen identical 16" wheels here locally as low as $50 per corner (I should have jumped on that). $500 total with new/newish stock takeoff tires seems fairly common
  5. Dec 15, 2015 at 7:31 PM
    JeffreyB
    JeffreyB [OP] Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Hey everyone thank you for the help on this. I have decided that I am going to hold off on wheels for now unless I come across an absolutely spectacular deal. The TPMS situation makes it into a little bit more than I am willing to get into at this point. Some day I will probably do something with the wheels though. Thanks again I appreciate the help!
  6. Dec 15, 2015 at 7:56 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I just saw someone on the Craigslist for Bozeman, MT listing these wheels from a 2014 Tacoma with the TPMS sensors for $450.
    You might contact him and give him a lower offer perhaps. Might solve your sensor issue!
