questions about camper shells for my Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, May 23, 2012.
  1. May 23, 2012 at 5:22 PM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    i have an 01 tacoma extra cab (four doors)
    i know it has a smaller bed the the regular cab models.
    looking for a truck cab and was curious if anyone knew the measurements i needed off hand and if there were other model trucks that have similar bed dimensions that would have shells that would fit my truck.
    im in the boston area.. any leads would be appreciated
  2. May 24, 2012 at 4:46 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Unless you order new you will probably have a hard time finding one used as all the trucks lately seem to have different dimensions. As to measurements, just measure from the front face of the box to just beyond the tailgate and for width about 1/4 inch over either edge then at least you will have some dimensions to use when you measure or ask for the measurements of used shells.
  3. May 24, 2012 at 7:43 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Sorry, can't help with the measurements, but potential sources for you I would suggest Craigslist. Seems like quite a number of shells listed on there regularly.
    Interestingly, I got a new boot for my shell (xtra cab model) from a large campershell place and found that they stock used shells as well. They take them in trade on a new shell when someone buys another truck etc. Might be worth a call around your area and see what is available. You might have to check weekly as stock probably changes.
    Would imagine least expensive route would be Craigslist.
    Hope that helps
  4. May 24, 2012 at 7:57 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Just buy a new one do then you don't have to worry about fitment issues
  5. May 24, 2012 at 8:10 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Your bed measurements on that xtra cab are 74.5x57.9
    Because of the vehicle width, I am pretty sure those dimensions are unique only to the 1st-gen 6' bed (actually 6.21').
  6. May 24, 2012 at 8:51 AM
    Madjik_Man
    Colorado Front Range
    Just FYI, you have a double cab.
    Not an extra cab.
  7. May 24, 2012 at 10:01 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    dammit which means more work for me
    ok if you have a DOUBLECAB your bed dimensions are 61.5x57.9
