Questions about coil springs: length, preload, and spring rate
Discussion in 'Suspension' started by ForestRunnerFrank99, Aug 2, 2019.
  1. Aug 2, 2019 at 12:31 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Ride preference plays a role too, along with shock valving and all that good stuff. But yeah when you have the v6, double cab, heavy plate bumper + winch, 1/4" steel skids and dual batteries you need some extra help from the springs lol
  2. Oct 20, 2020 at 3:55 PM
    crhsharks12
    crhsharks12 Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    If you go lower (from a 14 inch spring to a 13 inch spring), are you losing travel? What are the cons Of that?
  3. Oct 20, 2020 at 4:10 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    What rate spring rate? A few other spring length questions. How long are the springs not installed on shock? How long are they when installed with no added preload? With no additional preload how much do they compress when vehicle weight applied? How much preload did you add to achieve desired ride height? What does this all tell me? One thing not discussed normally is how much stored energy is there. If you can find a truck scale see if you could get your truck weighed (total and each axle). A garbage transfer station would work as well if they have a scale. A good source for help is www.accutuneoffroad.com
    AccuTune Offroad likes this.
  4. Oct 20, 2020 at 5:03 PM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    :confused: Shock travel will not change if the spring is changed. 13" spring is what comes factory from Fox, any change in spring rate would usually push you into a 14" spring since Eibach doesnt make a 13" long spring. No cons to going to a 13" spring, unless you have added weight to the truck.
    https://accutuneoffroad.com/articles/coilover-spring-rates-for-toyota-tacoma-4runner/
  5. Oct 20, 2020 at 6:13 PM
    crhsharks12
    Denver, CO
    That’s what I had figured, but someone made me second guess my opinion haha. Travel is travel, period. Also, thank you for the response accutune. Just read that forum a few hours ago! I am thinking of grabbing some 13” 600lb fox coils for my icons Since I have no weight up front. 650 is stiff smh
  6. Oct 21, 2020 at 5:36 AM
    Deo taco
    Deo taco Well-Known Member
    2017 trd pro in cement grey.
    Lots to come
    Hey @AccuTune Offroad what do you recommend for a long travel coilover truck with a steel bumper and winch. stock spring has way too much preload to stay at 3in of lift.
  7. Oct 21, 2020 at 8:03 AM
    AccuTune Offroad
    El Cajon, CA
    No hijacking threads! :D PM sent
    01 dhrracer likes this.
  8. Oct 21, 2020 at 8:07 AM
    AccuTune Offroad
    El Cajon, CA
    Well, if you would like to go that route... I may have a solution for you. PM inbound
