Questions about lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yotadriver21, Mar 6, 2018.
  1. Mar 6, 2018 at 11:01 AM
    Yotadriver21
    Yotadriver21 [OP] New Member
    2012 Toyota Tacoma prerunner
    Hey guys and gals, new to this forum, I drive a 2012 Toyota Tacoma prerunner with 3 inch lift
    Had a few questions
    What is the biggest tire I can fit with this amount of lift?
    What are my other options if I wanted to go bigger lift without breaking the bank?
    Do you guys recommend wheel spacers ?
    Finally if I wanted to keep just my 3 inch suspsension lift but go bigger should get lift blocks or a body lift ?
    Thanks guys!
  2. Mar 6, 2018 at 11:05 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    35s or larger if willing to cut, trim, chop, BFH.
    Spindle lift.
    I don't like wheel spacers, but they work.
    1" body lift is ok imop.
    I hate blocks.
    Use the search feature.
    Welcome to TW.
    TacoTRD78 and Chase8059 like this.
  3. Mar 6, 2018 at 11:07 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    If your a pre runner you should look at MaxTrax lift spindles. I believe they are 4.5 inch up front.
    Largest tires depends on what you mean by "fit". You can can go as big as you want, just be prepared to :sawzall:
    Mully likes this.
  4. Mar 6, 2018 at 11:13 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    No blocks or spacers , dont cheap out on a nice truck and put a shitty lift on. Do like @ChadsPride , he has Lift spindles and Dakar leaf packs. If you want over 3" lift.
    ChadsPride likes this.
  5. Mar 6, 2018 at 11:15 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Step 1. Call Marie @HeadStrong Off-Road and ask for the ChadsPride kit
    Step 2. Install said kit
    Step 3. Enjoy your sweet lift!
  6. Mar 6, 2018 at 11:18 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    If I had a Pre runner , Id get those spindles in a heartbeat. ChadsPride`s truck looks sick
    Oh yeah. Welcome to TW !!!
  7. Mar 7, 2018 at 3:31 PM
    ARDnc
    ARDnc Well-Known Member
    Charles
    2015 Toyota Tacoma
    Fab Fours Vengeance front bumper
    I have a 2015 Double cab TRD Sport, looking to lift it and run some 33 or 35 inch tires. I've been looking at the BDS 6inch Coilover lift kit, Fabtech, and the Procomp. Is anyone running these kits? Any issues? I'm into Surf Fishing on the Outer Banks of NC, just want some more clearance and I don't like trimming or cutting anything off the truck for tires to clear. I have the FabFours Vengeance series front bumper so that should help.
  8. Mar 7, 2018 at 4:09 PM
    Mully
    CA
    I am not into drop bracket lifts, they bend. Just do some real nice coilovers, trim, cut, BFH, cmc, and 35s. You will go anywhere. Good luck.
  9. Mar 7, 2018 at 4:13 PM
    ARDnc
    Charles
    2015 Toyota Tacoma
    Got ya, with out the drop brackets, is there an angle that is too much for the CV? I'm assuming that coilovers that are longer will push the rest of the axle down from the stock height. Unless that geometry doesn't affect the axle
  10. Mar 12, 2018 at 8:40 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    :rofl:Solid advice :thumbsup:
    TacoTRD78 and ChadsPride[QUOTED] like this.
  11. Mar 13, 2018 at 3:21 AM
    ChadsPride
