questions about my spacer + new front bilstein shock lift
Discussion in '5 Lug' started by Thorpedo26, Mar 18, 2012.
  1. Mar 18, 2012 at 6:45 PM
    Thorpedo26
    Thorpedo26 [OP] Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    Today i started my lift "pita for me" no power tools and im not mechanicly inclined... so i only got the front left on in a couple hours... Anyways the questions. After getting my new front shock with spacer and original coil on there was NO ROOM WHAT SO EVER for me to put the sway bar link back on. Is that normal or did i do something wrong? the video i watched made it look easy. Also i tried to use my jack to compress the suspension enough to connect the sway bar not happenin. Next, the UCA was a mm' if not touching the bottom of the coil. Is this normal ? i knew it was going to be tight but not this tight. Im afraid to take it to get alighned and have them be like lol wtf? im going to begin hunting for larger uca's but i thought it would be better off then this most of yall havnt had bad problems so maybe i did something wrong? Good note. That one wheel on looks sick and the height difference is awesome with my 265's ill add pictures later!
  2. Mar 18, 2012 at 7:03 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    disconnect both sides of the sway bar links, put the spacers on and button everything back up. Then put the sway bar links back on. Yes the a arm will contact the strut when its at full droop. When you set the truck down it will move away from the strut
  3. Mar 18, 2012 at 7:04 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    If you still cant get the sway bar link on with the suspension at full droop set the truck down after everything else is bolted up then connect the links
  4. Mar 18, 2012 at 7:32 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    Alright thanks man, ill check it out tomorrow when I get off work
  5. Mar 18, 2012 at 7:37 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Post some pics dude, ive been waiting to see those tires atleast half way mounted
  6. Mar 18, 2012 at 7:39 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    I'm looking at it sitting under the truck now, the sway bar sits super close to the uca and still looks like a big distance from being able to connect but will try tomorrow
  7. Mar 18, 2012 at 7:44 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    If its too far just drop it and then connect it
  8. Mar 18, 2012 at 7:55 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    Its dropped, I'm going to grab the connector and see if it fits
  9. Mar 18, 2012 at 8:08 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    No go :/ hmm. I was also looking at my coil and think if I spin it a little it will give me more play against my uca. Idk but thanks for helping with my q and a thread
  10. Mar 18, 2012 at 8:18 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Need pics to help further, I need to see what you see
  11. Mar 18, 2012 at 9:07 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    Alright tomorrow ill shoot some pictures if I can't resolve it!
  12. Mar 19, 2012 at 8:07 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    teaser shot of whats to come, didnt get to work on her today, but im about to go buy a impact wrench at wallyworld and finish tomorrow haha
    483613_3605056891823_1435663990_33549218_2c44dff3d162bc524eb27626b452e0bf6e4d5eb2.jpg
  13. Mar 19, 2012 at 8:11 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Maybe look into getting an Icon sway bar relocator??
  14. Mar 19, 2012 at 8:13 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    elaborate haha, what is it and is it 5 lug compatible?
  15. Mar 19, 2012 at 8:16 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
  16. Mar 19, 2012 at 8:20 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    try finishing up the other side before you try to connect the links if not then drop the sway bar with those relocation brackets
  17. Mar 19, 2012 at 9:57 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    I'm going to do the other side and see what happens. The sway bar things seem simple maybe home depot sells something similar? Haha
  18. Mar 20, 2012 at 6:52 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    if im not mistaken second gen sway bar links have a ball joint on them correct?
  19. Mar 20, 2012 at 9:00 PM
    Thorpedo26
    Brandon Thorpe
    Justin TX
    Yes they do! And p.s. they fit now that both sides are done haha. Tomorrow ill do the rear I haven't had time to do it at one sitting. What's the best way to Jack the rear end up? My jacks awful small and I need the rear axel hanging freely
  20. Mar 20, 2012 at 9:09 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Two jack stands on the frame closest to the front spring hangers
