Questions about Rear Brake Drums
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Devy, May 29, 2021.
  1. Jun 1, 2021 at 12:58 PM
    Devy
    Devy [OP] Member
    2013 Tacoma Base
    I'll give this a shot but what are "poor braking habits"?
  2. Jun 1, 2021 at 4:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There can be many. Did you read the links provided?
    Extremely hard stops and keeping the brakes clamped hard afterwards was what I was referring too. This causes pad deposits to bond to the rotors in that location. This will cause a pulsing sensation due to the uneven deposits on the rotor. Bedding the brakes tends to evenly coat the rotors with a layer of pad material. That is what is desired.
  3. Jun 4, 2021 at 12:31 PM
    Clearwater Bill
    Billy
    Largo Florida
    ^^ This. All. Day. Long.
    Your rotor and drums are both slabs of iron. Almost impossible to get hot enough to 'warp' by actual braking.
    You'd have strong brake fade long before you actually got to that temp from boiling the fluid.
    It's not uncommon for well serviced rear brakes to last 100k or more. It's not impossible for them to have a cylinder or other component causing a shoe to hang and wear out prematurely, but even that won't warp a drum.
    But you should pull the drums, clean everything, measure everything, make sure the adjuster is free and lube appropriate bits at least annually anyway.
