Questions about sand...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cheftroy1, Dec 19, 2017.
  1. Dec 19, 2017 at 3:50 PM
    Cheftroy1
    Cheftroy1 [OP] New Member
    Troy
    2018 4x4 taco
    None yet
    So I'm new here....
    I've lurked under multiple accounts for years. Now I'm finally getting a TACO!! 2018 ACLB 4x4 OR to be exact.
    the reason I'm getting the truck is to make it a beastly fishing vehicle from the surf in South Texas. But the area is called padre island national seashore. About 55 miles of untouched beach that's 4x4 access only. And we're talking deep sand!!! I'm getting the OR so I can have a locker. I've been stuck there burried to the bumpers before.
    So... bigger tires that can handle normal DD duties and still be able to handle the sand?
    Thanks
    Riding Dirty likes this.
  2. Dec 19, 2017 at 3:54 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    wider the better. Deep sand doesn't care about tread patterns.
  3. Dec 19, 2017 at 4:09 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    Here is my AC -- BTW --
    old55guy and Captqc like this.
  4. Dec 19, 2017 at 4:35 PM
    Cheftroy1
    Troy
    2018 4x4 taco
    None yet
    What step rail is that??
  5. Dec 19, 2017 at 4:39 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Consider getting some Maxtrax or traction boards as well if you’re worried about being stuck in deep sand.
    Welcome to TW!
    SuperBad likes this.
  6. Dec 19, 2017 at 5:29 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    And carry an air compressor so you can air down your tires for the sand and pump them back up to get home!
  7. Dec 19, 2017 at 5:29 PM
    markmizzou
    Mark
    Missouri
    That is a N-Fab I got for a nice discount from AutoAnything. The 3rd step is super handy when topper is off.
  8. Dec 19, 2017 at 6:19 PM
    Cheftroy1
    Troy
    2018 4x4 taco
    None yet
    Mantras and compressor check!! Thanks for the input. Anyone know how wide of a tire I can throw on with little rub? It will be getting a 2.5 inch lift the same month I pick the truck up.
  9. Dec 21, 2017 at 5:39 AM
    BlueDuck
    BlueDuck Member
    Ross
    2016 Tacoma
    None
    Captqc is spot on. I've done a lot of surf fishing in the NC OBX. Let your air down to about 18 to 20 lbs and I doubt you'll have any problems. Having a compressor onboard is nice.
  10. Dec 21, 2017 at 6:59 PM
    WetDogz
    WetDogz Member
    Doug
    2016 Tacoma
    My '16 2.7 AC SR loves the sand. With the stock hankoooks at 12lbs. it has never come close to getting stuck. I usually start out in 2wd just to see how far i might get. Sometimes I never need 4wd. A couple of inches of lift would definitely be an improvement as it bottoms out in bumpy stuff at speed..
  11. Dec 21, 2017 at 7:28 PM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I’m a sand guy (glamis , pismo etc ) and the trick is air pressure! Tires and lockers don’t matter as much in the sand. Let the air out untill you say “that’s to much” then let a little more out lol I have a low pressure gauge just for the sand . With the right combo you will drive anywhere you want.
