questions about the deckplate mod
Discussion in '4 Cylinder' started by TacoNinja12, Oct 3, 2010.
  1. Oct 3, 2010 at 12:04 PM
    TacoNinja12
    TacoNinja12 [OP] Well-Known Member
    Boone NC
    99 2.7L SR5
    3 inch lift
    so im looking into doing this but i was wondering some things. has anyone got any real data on it? Should i get a cold air intake or do this or not worry about it. people say you get more power but is that just more top end hp or bottom end or what? basically if youve done this let me know what you are getting, but give me more than "i did it i like it" if you have numbers then share them with me
  2. Oct 3, 2010 at 12:06 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    well all i can personally tell you is that would you rather waste 250+ plus on something that will work as well as something that costs $15?
  3. Oct 3, 2010 at 12:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On this first gens, dynos are showing an 8 hp gain on the v6, and about 5 on the 2.7. "CAI"s dont get that much, and cost way more.
  4. Oct 3, 2010 at 12:31 PM
    TacoNinja12
    Boone NC
    99 2.7L SR5
    3 inch lift
    ok sweet, is there a noticable difference or is just somethingthat people do when they get bored or what? cause im bored and i'll do it today probably if i knew it was worth it
  5. Oct 3, 2010 at 12:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Everyone I know, as well as myself, has felt a minimal difference. Gives a more throaty growl, and a little better mpg.
  6. Oct 3, 2010 at 1:02 PM
    TacoNinja12
    Boone NC
    99 2.7L SR5
    3 inch lift
    ok im doin it, i gotta go pick some stuff up now... i'll let everyone know how it goes
  7. Oct 4, 2010 at 10:42 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    My mpg went down... cause it just sounded so good and I couldn't quit stomping it. After I settled down I notice better mpg by about 1-2 and probably more power (butt dyno certainly says so). Also remove the silencer and plug the hole... that's where the noise comes from.
  8. Oct 6, 2010 at 7:03 PM
    thebaugh23
    thebaugh23 Member
    Eston
    blueridge mountains
    99 TRD 4cyl ex-cab
    3" ToyTec lift. keyless entry/ alarm. XM radio. westing burshguard, super 44 flowmaster, tinted windows, A/T tires, New Bilstein HD shocks
    how do you modify the deckplate? can i do it in the garage? what tools would i need?
  9. Oct 6, 2010 at 7:12 PM
    thebaugh23
    thebaugh23 Member
    Eston
    blueridge mountains
    99 TRD 4cyl ex-cab
    does anyone regret the mod?
  10. Oct 7, 2010 at 5:37 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Thats one huge plus about the deck plate mod, if you dont like it for whatever reason you can simply snap the cap in and leave it. it would then essentially be the same as stock.
  11. Oct 7, 2010 at 6:21 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    You can't really "feel" 5whp, unless well... your butt dyno is calibrated REALLY well...
  12. Oct 7, 2010 at 6:22 PM
    05RedTaco
    Tony
    Scottsdale
    Yeah... I wish 2nd gen airbox would be better designed so I could fit a deckplate on it...
  13. Oct 10, 2010 at 7:39 PM
    thebaugh23
    thebaugh23 Member
    Eston
    blueridge mountains
    99 TRD 4cyl ex-cab
    So is there a vid i can watch or steps i can get?
  14. Oct 10, 2010 at 10:14 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
  15. Oct 11, 2010 at 1:53 PM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    I got a 4 inch deckplate...then decided against installing it. Instead I took a 2.5 inch hole saw and drilled a hole in the front of the air intake box. So far I haven't noticed much power increase, but I do get a beefier sound. One of these days I might enlarge the hole in stick in a 3 inch deckplate.
  16. Oct 11, 2010 at 1:59 PM
    drifter
    Sam
    Oregon
    good stuff
    I'm guessing CAI's are more useful on other trucks than ours, otherwise, why are they so popular, besides sales hype?
  17. Oct 11, 2010 at 9:01 PM
    MowTaco
    Kansas
    Not everyone is fortunate enough to have the airbox setup we have to allow for it.
