Questions about the TRD Performance Air Intake System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mikhail2400, Aug 21, 2022.
  1. Aug 24, 2022 at 10:11 AM
    #61
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Dont listen to these neigh sayers. Butt dyno is the only dyno that counts
    Benny blanco likes this.
  2. Aug 24, 2022 at 10:11 AM
    #62
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Go 35s and 5.29s. You'll be blown away at how much power you can get to the ground with those big tires when u gear the truck properly
  3. Aug 24, 2022 at 10:19 AM
    #63
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Once I found out the TRD intakes still reuse the bottom part of the intake box, I decided to just go with the K&N 57-9039 JR Intake Kit (tube and filter) and the TRD Intake Flow Accelerator. Much cheaper and looks better and I can't imagine it would perform any worse since it gets rid of the baffle and accordion tubes. (It's also Carb certified if that matters to you)
    The truck feels better with this combo than it did with a fully stock setup. Smoother during accel and shifting. Can't tell if it's more powerful since I don't drive the truck hard, but that's not why I got it. But all in all the truck feels lighter. No ragerts.
    Longer post/review on it here.
    cropduster78 likes this.
  4. Aug 24, 2022 at 11:53 AM
    #64
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
  5. Aug 24, 2022 at 12:33 PM
    #65
    Mikhail2400
    Mikhail2400 [OP] Member
    K&N CAI 4 piece mud flaps LUCKYMAN CLUB D08-MX4 Seat Covers, Gray/Black
    When you changed out the stock intake tube with its resonator box did it change the sound when you kicked it?
    Looks good!! Where did you get the hood struts?
  6. Aug 24, 2022 at 12:35 PM
    #66
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    If not mentioned you can buy all the parts and get the intake cheaper. Sans air filter I got it all for about 240 on my 2nd gen. Airbox on 3rd gen is basically the same so you dont need the lower part only top part i recall.
    drizzoh likes this.
  7. Aug 24, 2022 at 12:48 PM
    #67
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    I covered that in the link I posted to my build thread.. but it's pretty much inaudible until around 4k rpm and then it absolutely screams, which is just about perfect IMO. Not annoying during DD but you will know you changed something when you punch it.
  8. Aug 24, 2022 at 4:09 PM
    #68
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Can anyone explain to me how the engine sound changes when a different intake is installed and also provide a physics based explanation for why it changes the sound? How do you hear the sound of your intake over the top of all the other noise the engine makes? It’s not making any sense to me.
  9. Aug 24, 2022 at 4:12 PM
    #69
    nudavinci64
    Robert
    good question. You wont really hear it unless you are hitting that skinny pedal hard. It then sucks a ton of air through, and there are no resonators to keep the sound down. The stock ones have resonators and things to keep it more mellow and aftermarket they get rid of it to allow a free flow which also makes it louder
    My interpretation of it anyway.
  10. Aug 24, 2022 at 4:13 PM
    #70
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Because the difference in Resonator's design or lack of..
  11. Aug 24, 2022 at 4:19 PM
    #71
    gudujarlson
    Minnesota
    A quick google search on air intake resonator leads me to suspect that your assumptions might be wrong. It appears that resonators are used to increase performance similar to how tuned exhaust helps increase performance.
    https://getjerry.com/car-repair/air-intake-resonator
    Grand Inquisitor likes this.
  12. Aug 24, 2022 at 4:41 PM
    #72
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    It says right in your link one of the reasons is for sound reduction.
    OldSaltyDog and shakerhood like this.
  13. Aug 24, 2022 at 4:45 PM
    #73
    gudujarlson
    Minnesota
    I might have understood you. I thought you were saying they removed the resonators to improve performance. Why would an aftermarket performance cold air intake have no resonators?
  14. Aug 24, 2022 at 5:04 PM
    #74
    nudavinci64
    Robert
    I know that when you go from a stock one they have built-in chambers to limit sound these are no longer there in an aftermarket setup.
    "The air intake resonator ensures that your car’s engine still works at capacity. It gives those pressure waves a place to expand and partially dissipate, resulting in a quieter, but significantly more powerful, engine. "
    The more powerful part is likely the debate on is an aftermarket intake worth it or not.
    sounds like its more then just to keep to keep it quiet and I seem to have the basic assumption they are saying.
  15. Aug 24, 2022 at 5:15 PM
    #75
    VaToy
    Parts Unknown
    Thank you, and yes it changed the sound around 3 to 4k rpm but since the latest Pro tune it sounds better in the lower RPMs now. The tune really makes the exhaust and intake sound even better. You don't even need to try and go wot to get the sound. The hood struts are Spikers with TRD stickers, but I have since removed the stickers and made them a little smaller and not as bold looking. I will take a pic later.
  16. Aug 24, 2022 at 5:18 PM
    #76
    VaToy
    Parts Unknown
    I picked up my CAI and TRD exhaust for about $750 total.
  17. Aug 24, 2022 at 5:24 PM
    #77
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Save your money cai isn’t worth it unless your just going for looks. I hear if you install gas hood struts it increases engine performance by 2%
  18. Aug 24, 2022 at 10:15 PM
    #78
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Dude would you share where you got that Toyota devil? He's bad.:thumbsup:
    #78
    Aqualoon likes this.
  19. Aug 25, 2022 at 8:17 AM
    #79
    Otto Mation
    Otto Mation Old on the Outside, Young on the Inside
    West Texas
    2018 TRD Sport 2019 Limited
    On eBay. Just search "Devilman JDM Decal" and you will find them. There is a seller that offers it in multiple colors and sizes.
    #79
    Fatback17[QUOTED] likes this.
  20. May 1, 2023 at 5:29 PM
    #80
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    edited
