questions about Toytec ultimate 3 inch lift
Discussion in 'Suspension' started by BigBawlzTaco, Jul 28, 2009.
  1. Jul 28, 2009 at 8:46 PM
    BigBawlzTaco
    BigBawlzTaco [OP] Well-Known Member
    2019 Toyota Tacoma SR
    I saved up enough to get this kit but the thing is, my truck is bone stock. Like i literally did nothing to it after i got it.
    but im gonna order 4 BFG MT KM2's and 4 Motometal 951's
    but the thing is when i install my lift kit do i have to worry about anything else?
    the wheels are gonna be 285/70/17
    and the wheels are gonna be 17X9
    so rubbing i understand and ill see if i can get a buddy to lightly trim my truck.
    but will i sag in the back or anything? i think the kit comes with a diff drop kit for the front and rear billie shocks
    and it says a toytec rear "long" add a leaf? what the monkey would i need it for, i thought if you had the shocks you wouldnt need the AAL's?
    correct me if im wrong, im still a novice with this stuff.
  2. Jul 28, 2009 at 8:51 PM
    BigBawlzTaco
  3. Jul 28, 2009 at 8:55 PM
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    The shocks wont raise the truck in the rear. You need blocks, AAL or a whole new leaf pack. The shocks just have longer travel to adjust for the rear being raised buy the AAL or whatever you put in there!
  4. Jul 28, 2009 at 8:56 PM
    Kmoney
    Kmoney Well-Known Member
    Kelly
    Bend, Oregon
    '17 DCSB TRD OR
    White dog
    The AAL is responsible for raising the rear end of the truck.
  5. Jul 28, 2009 at 8:56 PM
    BigBawlzTaco
    So basically the whole thing is set?
    i can install it and now worry about a thing?
    im probably going to get total chaos UCA's, heard good things about them
  6. Jul 28, 2009 at 8:57 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
  7. Jul 28, 2009 at 8:57 PM
    Kmoney
    Kelly
    Bend, Oregon
    '17 DCSB TRD OR
    White dog
    Yes... with the Ultimate Lift Kit you will be SET! :D
  8. Jul 28, 2009 at 8:58 PM
    BigBawlzTaco
    thank you guys!!!!!
    hopefully i cant go wrong with this :D
    i didnt wanna get the 6 inch because i didnt wanna cut the crossmember, i wouldnt offroad that much, AND it costs way too much. so hopefully this kit wont dissapoint me.
    THANKS!
  9. Jul 28, 2009 at 8:59 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    UCAs are in the front. I'll break it down a little to try and help out.
    The front is raised by either a longer shock, a stronger rated spring or a combination of the both in the form of a coilover. The UCAs allow you to get the correct alignment angles after the truck has been lifted.
    The rear is raised by an AAL or a block, and a longer shock is needed to fill in the new extra space created by the lift
  10. Jul 28, 2009 at 8:59 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah you should be good to go! TC UCA's will make the alignment right.;)
  11. Jul 28, 2009 at 8:59 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    its everything u need for the front and rear lift
    member Chocotaco has that lift check out his pics
  12. Jul 28, 2009 at 9:03 PM
    BigBawlzTaco
    how much do they cost normally?
    and instead of the UCA can i just do a little bit of trimming?
    what is the allignment?
    and i bet thats the noobiest question youve ever heard. sorry :eek:
  13. Jul 28, 2009 at 9:06 PM
    DanGer
    Questions ar not a problem, its how you learn!
    The UCA and rubbing are completely different issues. Alignment is the angles your tires meet the road. If it is out of alignment, tires will wear unevenly, the truck will wander on its own alot, etc. Aftermarket UCAs are needed to get you the correct allignment when lifting 3" or more.
  14. Jul 28, 2009 at 9:09 PM
    BigBawlzTaco
    but then i saw the TC UCA's and they are wayyyy to much for my budget. i only have about 5 thousand saved up.
    and the uca's i saw were like 2.5k
    thats not right is it??
  15. Jul 28, 2009 at 9:11 PM
    DanGer
    No they ar generally around $700
  16. Jul 28, 2009 at 9:13 PM
    BigBawlzTaco
    for front and back?
  17. Jul 28, 2009 at 9:14 PM
    DanGer
    $700 for UCAs only. they only go in the front :)
  18. Jul 28, 2009 at 9:17 PM
    BigBawlzTaco
    im such a chimp fucking noobie.
    hahahaha im sorry for the dumb questions, like literally i feel like running into a wall. :eek:
    but thanks for the help man. GREATLY appreciated.
  19. Jul 28, 2009 at 9:24 PM
    Kmoney
    Kelly
    Bend, Oregon
    '17 DCSB TRD OR
    White dog
    Don't feel stupid about asking questions! You have to learn somehow... You care about your truck and the people here have a lot of knowledge to offer!
  20. Jul 28, 2009 at 9:33 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2
    And X2.
    Don't be afraid of asking questions! :) That's what we're here for. :D
