Questions about truck bed; gap between bed and cab.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, Dec 15, 2013.
  1. Dec 15, 2013 at 2:07 PM
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    Hello all! I am new to the forum! I had a few questions regarding the truck bed and the gap between the cab.
    I notice that my truck bed inst necessarily straight. It appears that it is pretty much well aligned from front to rear in a sense that both rear tires are even as far as how much they stick out from the fender. My problem though is that on the drivers side, top and bottom of bed against the cab, measures about 3/4 of an inch. The passenger side however, measures about 1 inch on the top of the bed agaisnt the cab, and the bottom of the bed agaisnt the cab measures about 3/4 of inch. Basically, on the passenger side, when I look at the gap between the bed and the cab, there is more space in between the top than there is on the bottom. Has anyone else seen this on their 1st gen Tacomas
    ? Hope this makes sense. Thanks.
  2. Dec 15, 2013 at 2:12 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    check for a bent rear frame. common problem
  3. Dec 15, 2013 at 2:24 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    If your bed looks straight, Adam's right. But be sure to make sure it's not the bed itself that's tweaked.
  4. Dec 15, 2013 at 2:25 PM
    Zer0
    SGV, California
    99 PreRunner
    Thanks for reply. The rear bumper has a small dent on the passenger side but it appears to be a small fender bender. Could this have caused the frame to bend? How do i go about checking for a bent frame? The small dent looks like the previous owner backed into a pole or something. Thanks
  5. Dec 15, 2013 at 2:27 PM
    Zer0
    SGV, California
    99 PreRunner
    Sorry but I am a real newbie with tacomas and trucks in general. What is a tweaked bed? Anyway to fix this by adjusting the bed bolts? Is this a common problem? -and what causes tweaking. thanks
  6. Dec 15, 2013 at 5:53 PM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    bed is easy to adjust if bed alignment is what the problem turns out to be. Three bolts on each side easily accessible from underneath.
  7. Dec 15, 2013 at 7:32 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    A "Tweaked bed" refers to the bed being bent/misaligned as opposed to the frame being bent. 'tweaked' means bent, or generally not as it should be.
  8. Dec 15, 2013 at 8:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    since the rear portion of the frame that is comon that bends is all C channel..you'll be able to see it. Usually happens right around the area the frame goes from boxed to C channel.
  9. Dec 16, 2013 at 12:38 AM
    Zer0
    SGV, California
    99 PreRunner
    Thanks again for the replies! Im new to Tacomas so sorry for the rookie questions. Ill check the frame to see if I find anything that looks unusual. If this is the case, is this fixable by replacing a part or will it be something I have to live with :( My soul is getting eaten by this! How common is this problem and what causes the rear frame to bend? Can i add spacers or something on a bolt or 2 to lift up just that rear passenger side corner? Thanks!
  10. Dec 16, 2013 at 7:44 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    i wouldn't lift the passenger side. Our trucks also get "Taco lean" which is sagging on the driver side due to the gas tank, battery and driver all being on the same side. so when your driving it, its probably pretty dang level.
    frame can get bent from too much weight in the back and hitting a bump real hard. some times it takes a lot, some times not much at all.
  11. Dec 16, 2013 at 9:53 AM
    Box Rocket
    Adam
    Syracuse, Utah
    most common location for the frame to bend is right about where the upper shock mount is on the frame for the rear passenger side shock. That's where the frame goes to C channel. Sometimes you can see the top or bottom of the frame starting to buckle in that location.
