Questions about wheels and tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LewisRacing, Jan 26, 2011.
  1. Jan 26, 2011 at 2:50 PM
    LewisRacing
    LewisRacing [OP] Member
    Herbert
    Lanexa, Virginia
    ok guys,, yall helped me around xmas with my son's lift for his 07 Tacomo TRD off road, crew cab. We finally found time to get it on over the weekend. It went pretty smooth. We ended up with about 3.5" in the front and about 2.75 " in the rear. Now its time for tires. He was looking at a 305/70-16. So my question is what size tire is that? or will that lift take bigger? Also he wants the wheel to be kinda wide and stick out pass the fenders some. any ideas on a width of wheel and maybe what back space he needs? thanks a lot guys. Herb
  2. Jan 26, 2011 at 2:55 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    That tire is 33" x 12.2". It is pretty wide compared to most tires guys are running on 3" lifts. The wheel should be 4.5"-4" backspacing to help prevent rubbing. Even with that, some rubbing may occur depending on the lift. The cab mounts may need to be cut away and some fender trimming may need to be done in certain areas. Most guys run 285/75/16 which is almost an inch narrower so they dont have to worry about rubbing issues and they dont stick out as far.
  3. Jan 26, 2011 at 2:57 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    i would stick with 285/75 as Erik said. you'll need to do a fair amount of trimming as it is
  4. Jan 26, 2011 at 4:33 PM
    LewisRacing
    Herbert
    Lanexa, Virginia
    ok,, but the 285/ 75 seem kinda small. what size is stock so i can compare the 285 to a stock tire.
  5. Jan 26, 2011 at 4:37 PM
    CopDoctor
    08 335i
    285 is 33" .. they're huge compared to stock. stock is 265/70
  6. Jan 26, 2011 at 4:40 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    http://www.tacomaworld.com/forum/tirecalc.php
  7. Jan 26, 2011 at 4:40 PM
    CopDoctor
    08 335i
  8. Jan 26, 2011 at 4:55 PM
    especk
    Erik
    Redding, CA
    if you wanna get the 305s, get em. Yesterday I ordered 305/70/16 bfg km2 for my truck for when I install the OME lift in a couple weeks. I ordered an aftermarket offroad bumper because the front fender is where the majority of the rubbing would occur. I'm also ready to chop my cab mounts. You may want to do the same.
  9. Jan 26, 2011 at 4:59 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2018 TRD OR DCSB
    Keep in mind.. 285's will drop your gas mileage quite a bit..
    I know that is something that gets overlooked quite often.
  10. Jan 26, 2011 at 6:40 PM
    CopDoctor
    08 335i
    yep, i blew it off thinking the guys saying that were a bunch of complainers...until i started paying 40 every other week for gas :(
  11. Jan 26, 2011 at 6:56 PM
    08pretaco
    Oliver
    az
    80 bucks a month....I wish lol I am paying about 50 every 4-5 days
