Questions and concerns, Bilstein 5100's with Icon 1.5" add a leaf.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EPolBlueYota2019, Mar 24, 2022.
  1. Mar 24, 2022 at 8:28 AM
    EPolBlueYota2019
    EPolBlueYota2019 [OP] Member
    CAV BLUE 2019 TRD OR
    I'm hoping to rest assured that by installing my newly bought kit which is here below. Its a common kit I know but I hear from different people that lifting will be fine with no drive line vibration and others say you will have vibration and I will need a carrier bearing drop kit to take care of this. The setup I'm looking to run is front struts set at notch 3 which is rated at 1.1" re-using my stock springs. Rear looking to remove overload spring and install icons AAL 1.5". So this is nothing insane as lifts go so I'm wondering if anyone else is running this and what have your experiences been with ride quality and with any driveline issues or issues in general caused by lift? I also ordered the front diff drop kit but again I've been told I really wont need that since this is a mild lift. Please any thoughts or advice would help.
    2019 TRD Off Road, Tires are 265/70/R17 with Venomrex vr602's -12/ 17x9 wheels.
  2. Mar 24, 2022 at 9:16 AM
    guyfromky
    guyfromky Well-Known Member
    You're in the 2nd gen forum.
