Questions as a new Taco owner here
Discussion in 'Suspension' started by konane, Aug 14, 2021.
  1. Aug 14, 2021 at 7:47 PM
    konane
    konane [OP] Member
    Orion
    2008 Toyota Tacoma DBL Cab 4X4 4.0L
    None
    Looking into lifts and have a couple questions after reading some posts in this thread. Why is 3” lifts the standard as it seems? Is going higher than that inefficient or problematic? I’m looking into 5” or 6” lift by Fox Racing but am totally open to to more knowledge on the matter.
    Also, can you put a leveling kit on WITH a lift? Why would it a lift give you more clearance in the front than the back?
    Any and all suggestions and knowledge is helpful and appreciated, would like to build a real off-roading monster over the years.
  2. Aug 14, 2021 at 7:57 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Lifts over 3" increase Ujoint and CV angles causing drastically accelerated wear and vibration. Stock suspension is higher in rear to accommodate load weight in bed, thus the leveling.
    Also 3" lifts are much less expensive than all the modifications needed for drivetrain alignment.
    JC713 and Island Cruiser like this.
  3. Aug 14, 2021 at 7:59 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Welcome to TW, O!
  4. Aug 14, 2021 at 7:59 PM
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
    Above 2 inches and you go down the rabbit hole.
    BalutTaco likes this.
  5. Aug 14, 2021 at 7:59 PM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    The biggest reason, not even considering performance, is that the 5 and 6 inch lifts involve cutting and modifying the frame. They're nearly irreversible and when considering performance they decrease your truck's offroad performance.
  6. Aug 14, 2021 at 8:04 PM
    konane
    konane [OP] Member
    Orion
    None
    Awesome, that’s good to know thank you!
  7. Aug 14, 2021 at 8:05 PM
    konane
    konane [OP] Member
    Orion
    None
    Good to know before I go dumping a bunch of money into a lift that will exponentially cost me more than the purchase!
    davidstacoma likes this.
  8. Aug 17, 2021 at 4:04 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  9. Aug 17, 2021 at 4:26 PM
    gudujarlson
    Minnesota
    I’m skeptical the popularity of the 3” lift is due to cv angles. I think that gets regurgitated a lot on here. First I think most lifts that are labeled 3” are actually closer to 2” lifts when installed on a 3rd gen and 3” on a 2nd gen, however I’ve never fully fact checked this. I think the main reason for this size is that the Tacoma front IFS comes with about 3” of down travel from the factory and that is the extreme limit you can change the ride height. For best performance you want to leave some down travel, thus the popularity of 2”.
    You can go beyond 2” by using a drop bracket lift, but that gets very expensive. Also for 2wd spindle lifts are an option.
  10. Aug 21, 2021 at 6:02 AM
    konane
    konane [OP] Member
    Orion
    None
    So I’d likely be safer and smarter to go with a 2” and possibly put bigger tires on it just to add clearance without compromising ?
  11. Aug 21, 2021 at 4:58 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    But putting bigger tires also costs more.money like 33s or taller, you have to trim and cut a bunch of stuff up front, re gear the differentials if you go 34s or 35s.
  12. Aug 21, 2021 at 4:59 PM
    konane
    konane [OP] Member
    Orion
    None
    33 is my limit or 33 is where I’ll have to make alterations?
  13. Aug 21, 2021 at 5:08 PM
    Dalegribble02
    With my truck and 33a since I wheel it I hadto do a cab mount chop trim plastic an puund my pinch weld down. I'm not re geared but I should be, but that's because my truck is a heavy mofo
