Questions for the new 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tcgator, Sep 28, 2015.
  1. Oct 1, 2015 at 12:32 PM
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    If it was a true Canbus system then the computer would reprogram for the LED's. It did on my Harley!
  2. Nov 5, 2015 at 5:27 AM
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Sam you seem to know about the leds here. I just got my 16 Tacoma last night and the lights have to be converted to leds. Can you recommend a kit for the interior and also a good set if known for projector h/l and fog lights?
    As for Harleys I have a 12 CVO and have to install a load equalizer to convert my front turn signals, Im in the process of doing that.
    Thanks.
  3. Nov 5, 2015 at 4:13 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    Hi CVOTRDSPORT and welcome to the forum. I have not touched the interior lights but there are some posts from people that have. There have not been any LED's good enough to go in the projector Low housing. Those that may be a candidate are too long as they have the fan housing on the back(ie.. VLED) and there is no clearance for those. Besides the light disperses and you have a spread instead of a beam. Most have been going to Morimoto H11B HID lights from The Retrofit Source. They have the 16 Tacoma kit($150). I put the VLED LMZ Platinum in the Hi-Beam. The suggestion is to move the collar all the way back(bulb all the way out) and adjust so the leds are sideways(not up and down). There are many choices for the Fogs... and most do a fair job(but again they are LED and the light is a spread instead of a beam). I used Xenon Depot LED H11 Headlight and foglight kit. For the tail lights I used the VLED RED 21 LED 7443 7440 STANDARD BASE | 1 PAIR (2 sets) with a pair of VLR HD 6ohm load resistors(from VLED). Istallation was pretty straight forward and took about 10 mins once I identified the 2 wires to splice.
    TacoBella likes this.
  4. Nov 5, 2015 at 5:17 PM
    8102
    8102 Well-Known Member
    British Columbia
    2016 Toyota Tacoma Limited
    VLEDS LED Low Beam Headlights, VLEDS High Beam LED Headlights, VLEDS LED Fog Lights, VLEDS LED Triton Turn Signals and Brake Lights, VLEDS LED Interior Lights, Reverse, Licence Plate Lights, Stainless Steel OEM Exhaust Tip, Leer XL Canopy, Bed Rug, Diablo Grill Logo, mattgecko Engine Compartment Lights and Bed Lights.
    Hi Sam,
    For the rear reds did you use the VLEDS Triton's or the stand alone bulbs?
    Thanks!
  5. Nov 6, 2015 at 8:20 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    I used the standalone labeled as posted. There are no all white. Most are white/amber so I went with the red 170 lumens. Work well!
  6. Nov 7, 2015 at 10:53 AM
    8102
    British Columbia
    Thanks Sam B,
    I just ordered the VLED LMZ Platinums for my High Beams, how are yours working out?
  7. Nov 7, 2015 at 4:48 PM
    Sam B
    Samuel
    Poway, Ca.
    none
    I haven'the used them much but they put out a lot of light. Big light spread.
    8102 likes this.
  8. Nov 7, 2015 at 5:32 PM
    barnett
    barnett Well-Known Member
    Brian
    Franklin, Tx
    16 DC 4x4 Off-Road
    I went with the morimotto hid's. 55w and they are awesome. Cut off is great, gonna put the morimotto fogs tomorrow
