Questions from a noobie
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOma_2012, Dec 8, 2023.
  1. Dec 8, 2023 at 8:50 PM
    TACOma_2012
    TACOma_2012 [OP] New Member
    Recently purchased a 2012 Toyota Tacoma TRD Off Road. My First truck, second vehicle.
    My Fuel door only opens 80% unless you give it a little more of pulling. I’ve noticed that its probably because of rust build up thats why it has a hard time turning. I was thinking of replacing the fuel door, where could I buy a new one thar is already painted and it comes with all the hardware needed? This apparently will be my first to many mods to come lol, Also, any recommendations for a bed cover? Which isnt too expensive?
    really glad that i found this community online, thanks!
  2. Dec 8, 2023 at 9:22 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Before you go buy a whole new door have you tried WD40 and wiggling the door back and forth? Might work.
    TACOma_2012[OP] likes this.
  3. Dec 8, 2023 at 9:24 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I can only think of a wrecking yard. Try car-part dot com. If rust is the issue, have you tried a penetrant?
  4. Dec 9, 2023 at 5:48 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    I developed the same problem, Kroil solved it. A drop or two every time I change the oil has kept it moving freely. I keep a paper towel at the bottom of the hinge in case my 'drop or two' gets out of control.
  5. Dec 9, 2023 at 9:10 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Being in the rust belt I sprayed the inside of mine with a cosmoline product. Then the door became hard to open so I sprayed the hinge with a silicone product. It now opens and closes freely.
