Questions - OEM vs. Aftermarket Locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ihatetacomas, Dec 12, 2015.
  1. Dec 12, 2015 at 7:44 PM
    Ihatetacomas
    Ihatetacomas [OP] Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    How much would you imagine it would be to install an OEM rear locker?
    Any advantage ARB has over the OEM locker?
    Can I have a LSD in the front and locker in rear? Or does it not work like that :confused:
    Any way to convert my TRAC to A-TRAC?
    Would installing the OEM locker at the dealership be worth it since it would be under warranty?
  2. Dec 12, 2015 at 8:12 PM
    Pigpen
    Dan
    Northwest Montana
    You'd need to change out your whole brake system, add the elocker electronic system, and elocker axle. You'd spend more money for a truck that not as capable. Save some money and do ARB front and rear. Put the money you save into the suspension. You could probably afford a nice ICON setup.
    Tarzan13 and DoorDing like this.
  3. Dec 12, 2015 at 9:21 PM
    Ihatetacomas
    Dylan
    Elko NV
    I'll let the pros install it, as much as I would like to do it myself I don't have the experience.
    So is my LSD (and any 2nd gen OR locker) located in the rear diff? Which means open/conventional diff in the front?
