Questions on a lift?
Discussion in 'Suspension' started by TRD2006, Jan 22, 2013.
  1. Jan 22, 2013 at 6:27 PM
    TRD2006
    TRD2006 [OP] Well-Known Member
    stock 2006 4x4 TRD Sport
    Okay so I installed the bilstein 5100's, they are set to 2.5 with stock coils... I've read many threads and none seem to be my issues, my issue is that around 25 mph the truck shakes pretty hard and also sometimes even at 45-50. I'm trying to figure out what it is?
  2. Jan 22, 2013 at 6:30 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Any lift in the rear? Same vibes in 4wd?
  3. Jan 22, 2013 at 6:31 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Did you get an alignment?
  4. Jan 22, 2013 at 6:34 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Stolen from your other thread. So AAL in the rear, have you tried shims or dropping the carrier bearing using spacers?
  5. Jan 22, 2013 at 6:38 PM
    TRD2006
    No I haven't, it does change in 4wd at least with the slight whine I haven't really tried all that mouth but just the past 2-3 days the shacking has gotten worse the add a leaf is a 2 inch rear
  6. Jan 22, 2013 at 6:39 PM
    TRD2006
    I also did get an alignment
  7. Jan 22, 2013 at 6:43 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    There is a couple really useful threads on here about how to correct vibrations caused by the driveshaft. Unfortunately there is no cure all solution, some people have good results with one method some with other methods. I would start by dropping you CB and see if you get any results, mainly because i think that is less work than installing shims on the axle beneath the leaf springs.
  8. Jan 22, 2013 at 6:48 PM
    TRD2006
    Okay, is that my cause?
  9. Jan 22, 2013 at 6:59 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Possibly, vibrations could be caused by the front diff also, seems like it is more common for vibrations to be caused by lifting the rear end though. You can "experiment" with the carrier bearing by simply adding washers to drop it. This thread is very in depth http://www.tacomaworld.com/forum/2nd-gen-tacomas/244535-drive-shaft-vibrations-solved-step-step.html
    It is a little confusing and alot to read but it may help you understand what is going on.
  10. Jan 22, 2013 at 7:09 PM
    TRD2006
    Ok I'll take a look thanks
