Questions on Cutting up the storage bins a SC
Discussion in 'Audio & Video' started by Mtek, Jan 1, 2012.
  1. Jan 1, 2012 at 6:45 PM
    Mtek
    Mtek [OP] Well-Known Member
    WA
    '11 TRD Sport DCSB 4x4
    TRD S/C Toytec OME 3", TRD Ivan Stewarts, 285 Yokohama
    Hi all,
    What tool did those of you who cut the black storage bins use? I am going to try and make the sub area look more finished and wanted to use the upper portion of the bins for a more finished look. Anyone carpet them as well, so it matches the box? Any tips or advice appreciated. Thank you.
  2. Jan 1, 2012 at 8:44 PM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    Oscillating tool, in my case the Ridgid Jobmax. Dremel was an option, but I prefer the Jobmax for this type of work.
  3. Jan 1, 2012 at 8:59 PM
    bigswoleone
    bigswoleone Well-Known Member
    Craig
    Birmingham, AL
    11 DC PreRunner TRD Sport
    Alpine CDA-117 HU DLS Ultimate UP6i 6.5" comps Polk 6.5" coaxial rear-fill Polk MM series 10" sub Kicker ZX700.5 amp
    Rockwell
  4. Jan 1, 2012 at 10:29 PM
    Mtek
    WA
    Thanks guys, I have a dremmel so I am going to give it a shot.
  5. Jan 2, 2012 at 7:07 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    A dremel will cause friction, and a lot of heat. This tends to melt plastic, which does not give the most visually appealing results. They will work fine for cutting it, but be prepared to come back with a sharp knife to clean off the melted areas, and then take some fine sand paper to the edges to finish them a little better.
  6. Jan 2, 2012 at 3:50 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ^^^ this... Use a low speed if you do use a dremel, or I used a pair of tin snips most recently.
