Questions on Icons
Discussion in 'Suspension' started by Canadianboy, Sep 11, 2009.
  1. Sep 11, 2009 at 7:11 PM
    Canadianboy
    Canadianboy [OP] Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I just have a few questions about my ext coilover Icons that I just installed.
    1) I was just checking over everything in the front end. When I had the
    spanner wrench in the coilover, without loosing the little allen bolt,
    I would spin the spanner wrench, the shock would move left and right
    in the coil. Is this normal, or did I forget to tighten something on the
    Icons before I installed them?
    2) I have about about 1 3/4 of thread showing. When I hit bumps and holes
    in the road, I can feel them quite a bit more then when the truck was
    stock. I know its not a Cadillac lol, just want to check that this is normal.
    I wouldn't say that the feeling is 'harsh', but I can def notice little bumps.
    I also have new tires and rims, set at 35 psi. However, I really noticed that the truck corners a lot better then stock with the Icons, huge difference here.
    3) I had an alignment done, the tech set the caster at 4.4 on the left and
    4.8 on the right. Is this too much caster?
    This was my first time installing a lift kit myself, so I'm just double/triple
    checking that I did everything right. Thanx guys.:)
  2. Sep 11, 2009 at 9:25 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Did the spring move just a tiny bit then stop, like slop? I would emagine that's because of how the top of the shock attaches to the top of the coilover housing/plate/gizmo that has the 3 bolts on it. If it's like Camburgs or SAWS or whatever it's a pivot joint designed to move in one particular direction but it's naturally gonna have a tiny bit of slop, I would think.
    Plus there is similar/same kind of slop on the bottom too. I think.
    Edit:: even if it does spin with it doesn't matter. There is nothing to keep the spring from moving when you adjust but any friction present.
  3. Sep 11, 2009 at 9:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Caster is way too much. It should be around 2.8*
  4. Sep 11, 2009 at 9:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok...but it "should" be 2.8*
  5. Sep 11, 2009 at 9:57 PM
    Canadianboy
    James
    Vancouver, BC
    Ok thanx guys. What would happen with such high caster? Bumpsteer more noticable? Anything else?
  6. Sep 11, 2009 at 9:58 PM
    azTRD
    azTRD Well-Known Member
    The specified range for caster is 1.3-2.8, so 2.8 is at the upper end of the scale.
    Chris... I know that you mentioned in the post I linked below, that more caster angle pulls the wheel further back towards the rear of the truck. What is the benefit in having the wheel set back further? I would think you'd have more issues with rubbing on the cab mount.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/40470-ucas-alignment.html
  7. Sep 11, 2009 at 10:01 PM
    Canadianboy
    James
    Vancouver, BC
    I'm confused now. I thought a higher caster would move the wheel forward in the wheel well? I'm worried now about having my caster lowered and having issues with my tires hitting my cab mounts.
  8. Sep 11, 2009 at 10:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The addition of Caster correcting UCA's moves the wheel back, an alignment brings the wheel more forward, which is why I say 2.8* Caster. Adding Caster after installing the UCA's moves the wheel forward, as the Caster adjustment is done with the LCA.
  9. Sep 12, 2009 at 6:28 PM
    Canadianboy
    James
    Vancouver, BC
    Thanx, I'll have to get my alignment re-done then with a lower caster. I have to jack my truck up again and re-look at everything, everytime I hit a low speed bump, its squeaking like an old, beat up junker! I have lots of teflon lub on the uni-ball, so I don't think its this. The squeaking sounds like its coming from the Icons or from the bushings on the main bolt, kinda hard to tell. But its sure annoying everytime I go over a speed bump!
  10. Sep 12, 2009 at 6:56 PM
    chad68
    Chad
    OP What control arms are you using?
  11. Sep 12, 2009 at 7:24 PM
    Canadianboy
    James
    Vancouver, BC
    Total Chaos ucas. I just had the truck up and down on the jack to cycle the suspension. I am almost 100% sure the noise I'm hearing is actually coming from the bushings on the main bolt. When the uca pivots on the bolt, you hear the noise. I put more grease through the zerks, then it started coming out the side of the bushings, so I think I have enough grease in there. The only thing I can think of, is I didn't put enough grease on the side of the bushings or between the washers and bushing??? Either that or I have the main bolt done up too tight?? I may have to take the ucas apart to figure this out, I can't live with this noise.
  12. Sep 12, 2009 at 7:28 PM
    ghostboy808
    ghostboy808 Well-Known Member
    Silver Mica Prerunner TRD Sport
    Gibson SS, TRD S/C
    Mine does all of the above too. The shock rotates back and forth if you put the spanner wrench on it. I'm pretty sure that is normal, I just center it after I'm done adjusting it.
    I don't know where the squeak is coming from but just happens everytime I hit a speedbump too, kind of like a little mouse is living in my shocks.
    The ride will be stiffer because the icon springs are stiffer than stock. The Cadillac analogy is not accurate when people describe it as such. When you go fast and hit a bump these can recover better than stock so you won't bottom out.
  13. Sep 12, 2009 at 7:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  14. Sep 12, 2009 at 7:29 PM
    chad68
    Chad
    I was thinking maybe the sound was coming from the bushings on your arms. Did you try spraying the ends of the bushings where the washers are with a little WD40? I'm wondering if like you said maybe the bushings didn't have enough grease on them when you installed them. I'm not sure but maybe those zerk fittings don't get grease to 100% of the bushings?? Maybe it's just the ends of the bushings that don't have enough grease.
  15. Sep 12, 2009 at 7:33 PM
    Rollinn
    Rollinn Well-Known Member
    Vegas
    06 Prerunner sport
    Icon 2.5 c/o,TC uca, bhlm mod, nav, etc etc
    i just installed my icons this weekend, i think that the movement your talking about is the whole entire c/o itself moving left to right.. YES this is normal-its designed like that as there are misalignment spacers in them.. its completely normal..
  16. Sep 12, 2009 at 7:37 PM
    Canadianboy
    James
    Vancouver, BC
    Ok, won't worry about that then. Rollin, do your Tc uca's make any noise from
    the bushings on the main bolt?
  17. Sep 12, 2009 at 7:41 PM
    Canadianboy
    James
    Vancouver, BC
    Yeah I read the 'cadillac' reference I few times, then I felt the Icons to be pretty firm so I just wanted to double check. Its a truck so I'm not too concerned about this. But the truck sure corners a lot better now, almost no body roll.
  18. Sep 12, 2009 at 7:44 PM
    chad68
    Chad
    Is it possible you can jack it up and take the coilover out and cycle the suspension up and down by hand to eliminate the coilover as being the noise? Then if still there, disconnect the ball joint and just cycle the UCA up and down? That should tell you whats causing the noise?
  19. Sep 12, 2009 at 8:00 PM
    Rollinn
    Vegas
    06 Prerunner sport
    mine do not make any noise whatsoever.. I would try and loosen the main bolt and spray some white lithium grease in the bushings and then torque to specs.. It should be something very simple, but I dont think you need to remove it all in order to alleviate the problem.
  20. Sep 13, 2009 at 10:03 AM
    Canadianboy
    James
    Vancouver, BC
    Thats a good idea, I'm going to disconnect the uca ball joint tonight and move it around to see if it makes the noise. I'm pretty sure its the bushings on the main bolt making the noise. I may just take the whole uca out, clean and then re lube.
