questions on lift and rear spring TSB!!!
Discussion in 'Suspension' started by tecatequikness88, Jan 13, 2009.
  1. Jan 13, 2009 at 5:40 PM
    tecatequikness88
    tecatequikness88 [OP] Member
    if i get the rear spring tsb done do and wan tto do a 3 inch toytec lift do i have to tuch the rear at all or will the tsb be ok. The reason i ask is im hoping to get he tsb done and buying a toytec lift with the lift springs and 5100s but ? thnaks
  2. Jan 13, 2009 at 5:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your gonna need to bring the rear up an inch or so to sit level.
  3. Jan 13, 2009 at 7:08 PM
    Kicker_Of_Elves
    Kicker_Of_Elves If it bleeds we can kill it
    USA
    08 Tacoma Access Cab TRD Off Road
    Front Skid Plate, Exhaust Tip, Tinted Windows: 35% Front Sides, 5% Rear Windows, Devil Horns Emblem, Rear TSB, BLHM, Shorty Antenna, 6000k HID Headlights.
    Toytec actually sells a rear aal set designed for trucks with the TSB done heres the linky:
  4. Jan 13, 2009 at 9:35 PM
    cfenn
    cfenn Well-Known Member
    San Antonio, Texas
    PreRunner
    TRD exhaust,TSB, 5100's on the front, 884 springs, Total Chaos UCA, 5100's on the rear, Wheelers HD rear springs , Nitto 285/70/17's on MB TKO 17x8.5's
    I have the tsb springs on my 07 and 5100's at 2.5" and the front is 1/2" lower than the rear
  5. Jan 14, 2009 at 1:20 AM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    Got any pics, I would like to compare.
  6. Jan 14, 2009 at 4:01 AM
    tecatequikness88
    ok thanks guys thats what i thought
  7. Jan 14, 2009 at 7:32 AM
    cfenn
    San Antonio, Texas
    PreRunner
  8. Jan 14, 2009 at 7:49 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I have the TSB springs and ToyTec coilovers up front set at about 3". My front end is .5-1" higher than the rear now that the TSB springs have settled. I'm probably going to be replacing the rear spring packs soon.
  9. Jan 14, 2009 at 4:09 PM
    Overheadspec
    Overheadspec Member
    Houston, TX
    08 Prerunner Longbed
    Cfenn,
    That looks good; What size tires and wheels are those (backspacing, wheel size, and tire size)?
  10. Jan 14, 2009 at 9:35 PM
    cfenn
    San Antonio, Texas
    PreRunner
    285/70/17 on pro comp 7089 17X8 with 4.5 bs
  11. Jan 14, 2009 at 10:08 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Hmm. I've got the TSB (the newly revised one though) with a 1" block under it and 3" coil spacers on the front and my truck is low in the back, visually though. If i measure it by fenders it is almost level, but it just looks too low in the back. When I swapped my studded tires on I threw the jack under my reciever to see how much more I need to add to it to make it look level and came up with about 1.5". So on this note you'll probably want the Toytec AAL in the back, thats what my truck is getting next. If my camera werent dead I'd post some pics, sorry.
  12. Feb 28, 2009 at 12:49 PM
    docuw
    docuw Active Member
    SLC, UT
    09 Tacoma DBL TRD Offroad
    3" Lift: Front - OME 885 Springs with N140S, Toytec 1/2" Spacer; Rear - TSB Leafs with Toytec TSB AAL and OME N182S. Total Chaos UCA's, Access Tonnaeu Cover, Dynolock Tailgate Lock, Polished Aluminum Bull Bar, Bed Mat.
    Does anyone have any knoweldge on the ability to get the TSB leaf pack for the 09 Tacoma? I dont have any understanding as to why Toyota knew these leaf packs sucked 3 years ago, but still put them on. My 09 Dbl Cab TRD Off Road w Tow Pkg has the weak 3 leaf pack on it still. I want to do a 3" OME with AAL in the back, but am concerned that when the finally do add the 09 to the TSB, I will already have added the lift, and they will balk.
