Questions on OME lift and ARB Bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunter500ky, May 29, 2011.
  1. May 29, 2011 at 10:22 AM
    #41
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    My 886 coils with ARB bumper gave me 3 3/4 inches of lift, after they settled they are still at 3 3/8.
    Your stock UCA's will be almost maxed out, and will max out when you roll ever a speed bumpe etc and your suspension tops out; therefore it limits your suspension travel. You will definately hear it.
    I went with LR UCAs.
    Also $200 for the assembly is very cheap and worth it, as it included Toyota factory parts, so you can so a direct swap.
    Also when you mount the bumper, have at least a 20mm clearance between it and your fender; anything less and it will rub from the chassis movement/flex.
  2. May 29, 2011 at 10:22 AM
    #42
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You can get a little more travel out of the LR UCAs. Mostly the fix the alignment.
    Here were my numbers after 886s, before UCAs.
    Not very good.
    Like I said, I drove around like that for a long while until the 33s made it just too apparent.
    My alignment is now like 0 toe 0 camber 2.8* caster.
    You'll have to decide how it is for you, each truck is slightly different as well, but in all likely hood your truck won't be in spec. It also may slightly affect tire wear as well so you'll have to take all this into consideration and make the call.
  3. May 29, 2011 at 10:34 AM
    #43
    Hunter500ky
    Hunter500ky [OP] Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Sounds good, worst case that means new tires sooner :) lol!!!!
    Ill prob end up getting a pair 450 will take me a month or two though.
    Its official we made a deal on the bumper!!!
    600$ brand new all hardware, only downfall no fog light holes :(
  4. May 29, 2011 at 10:38 AM
    #44
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Damn good deal! Congrats.
  5. May 29, 2011 at 10:43 AM
    #45
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Thanks im stoked!!!!!
    5 hour drive though lol, i know friends in that area though so its ok!!!!
    Now looking for some 886s incase the 885s fall through.
    Theyre on ttora i think its called waiting on my account to be activated... So i can send him a pm
  6. May 29, 2011 at 2:21 PM
    #46
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Found a set of 886s prob going to be purchasing them still kind of iffy really dnt want over 3" of lift but trusting you guys!
    Emailed wheelers about what shock I need for the rear end and the ill be ordering and rolling!!!! So stoked!!'
  7. May 29, 2011 at 2:31 PM
    #47
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Get OME front shocks if you get the 886's
  8. May 29, 2011 at 2:35 PM
    #48
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
  9. May 29, 2011 at 3:50 PM
    #49
    Woodstocktaco
    Woodstocktaco Well-Known Member
    Woodstock, GA
    09 SR5 ORDC 4X4
    3" OME lift, 885 coils, Dakar rears, diff drop
    Great deal on the bumper!
    Where is "E-town"? I lease hunting property in Todd Co. - are you over that way?
  10. May 29, 2011 at 3:55 PM
    #50
    covefrog08
    covefrog08 swollen member
    Vancouver Island- Canada
    08 w/west coast pin-striping
    devil horns, weather tech floor mats, Camo seat cover, window visors, premier deck w/ 6 speakers and sub, checker plate tool box, diff breather relocate, Mag light & Fire Extinguisher behind seat
    ouch. catastrophic failure id say wonder how that happened
  11. May 29, 2011 at 8:47 PM
    #51
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Woodstock im near lousiville im still new here so dunno where that is.
    Can anyone get me very very good measurements on the arb bumper? Hoping it will fit in the car but it doesnt look like it, it would be greatly appreciated
  12. May 29, 2011 at 8:50 PM
    #52
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    wow rreally? that much lift??
    i may need to run 2 sets of D29XL stacked in my Dakars to be no Bro.
    Also post some pics of your truck mang.
  13. May 29, 2011 at 10:12 PM
    #53
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Mine gave me MUCH less. :confused:
    I'd say 2 and 3/4 maybe? check the pictures I posted above, 886s dakars. Decide for yourself
  14. May 29, 2011 at 10:16 PM
    #54
    OZ-T
    Peter North
    British Columbia
    1 is already gonna be too much .
  15. Jun 9, 2011 at 10:40 AM
    #55
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    I can't seem to find a straight answer and I've searchd my ass off. I don't want to start a new thread, so I'll ask in here. Sorry to hijack, Hunter. :eek:
    I ordered a ARB and DO NOT plan on running a winch. I understand that 886s are what to get if planning to have both.
    I've also read about 886s chattering your teeth without the extra 75-100 lbs of a winch. With the ARB alone, do y'all think it'll be somewhat level with a 2" aal? (non tsb rear) using 885s and using a 1/4 top plate spacer or should I get 1/2"? I'll be using 5100s since I already have them.
    I'm a dclb. Thanks for any input.
  16. Jun 9, 2011 at 10:44 AM
    #56
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    885's should be good
    That is IMO
    It will give more the an 1" prob 2" maybe a tad more.
    It will be 3ish at first but remember it has to settle
  17. Jun 9, 2011 at 10:58 AM
    #57
    LEX
    Houston, Texas
    100 Series LC
    Curently, I have 5100s set at .85 with Eibachs + 1/4 plate spacers with 2" aal. It settled at about 2.5..maybe a tad more.
    I'd like to settle higher than what I have now. 3" would be good. I feel that I have too much rake.
  18. Jun 9, 2011 at 11:13 AM
    #58
    OZ-T
    Peter North
    British Columbia
    The 885's with no spacer got me just over 2 1/2" up front in my DCLB 4x4 , I would suspect you will sag an inch with the ARB up front .
    If you add the spacers for the full 3" lift and sag an inch , adding a 2" AAL in the rear will have you at the factory rake . ie up 2" above stock front and back
  19. Jun 9, 2011 at 11:34 AM
    #59
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    I installed an ARB with a winch a couple months ago and I'm still running my 884's with stock shocks. The ride is actually very nice! I don't top out my UCA's over speed bumps anymore. However; I do rub a little bit off road so I am looking to get some 886's soon or some coilovers.
  20. Jun 9, 2011 at 2:38 PM
    #60
    OZ-T
    Peter North
    British Columbia
    Probably your best bet , but keep in mind you are supposed to only run OME shocks with the 886 coils , not Bilsteins
