Questions on Toytec Ultimate DIY Install
Discussion in 'Suspension' started by lmnt, Nov 2, 2010.
  1. Nov 2, 2010 at 8:25 PM
    lmnt
    lmnt [OP] Active Member
    Well I took the plunge and started the install of my toytec ultimate lift over the weekend. I got the shocks in on both sides and the sway bar relocate done. Drove it around and all is well at the moment. I did come away with a couple of questions:
    1. How do you torque down the top shock mount bolt that is in the back. No problem with the front two, but the back one I just had to guess because I couldnt get the torque wrench to fit back there.
    2. The diff drop can be done with all wheels on the ground correct?
    Tip for those that will do this in the future and have no mechanic experience (like me). DONT use a pickle fork on the ball joints, use the hammer technique, it works. I busted one of my front steering ball joints for no reason.
  2. Nov 2, 2010 at 8:36 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    1. don't know
    2. yep!
  3. Nov 4, 2010 at 3:52 PM
    lmnt
    So I guess by the response that no one torques that bolt in the back to spec?
  4. Nov 4, 2010 at 4:02 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    i didn't torque it to spec. just be sure to retighten after a few hundred miles or so.
