Quick Bed Mat Mod (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Oct 19, 2008.
  1. Jun 4, 2017 at 5:32 AM
    #61
    StevieD
    StevieD Well-Known Member
    Tampa
    2007 tacoma
    I did the same except I used a D ring for the extra tie down.
  2. Jun 4, 2017 at 6:07 AM
    #62
    2003 4x4
    2003 4x4 Well-Known Member
    2003 taco 4x4 & 2017 TRD OFFROAD
    Where did you get the new d-rings to fit the anchor bolts?
  3. Jun 4, 2017 at 7:45 AM
    #63
    StevieD
    Tampa
    2007 tacoma
    Amazon Toyota D rings. Home Depot galvanized carriage bolt ( the one with the rounded top), washers and nut. Painted them black, let them dry and then installed.
  4. Jun 4, 2017 at 7:51 AM
    #64
    StevieD
    Tampa
    2007 tacoma
    Also I used 3 or 4 washers under the bed mat so the mat surface remained level when I tightened it down.
  5. Jun 4, 2017 at 7:55 AM
    #65
    StevieD
    Tampa
    2007 tacoma
    I just read you post all of the way thru. My truck has 3 drain holes under the mat up next to the cab. I used the middle hole.
  6. Jun 4, 2017 at 8:57 AM
    #66
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    did you buy your truck used? I wonder if someone drilled 2 more.
  7. Jun 4, 2017 at 1:41 PM
    #67
    StevieD
    Tampa
    2007 tacoma
    2007 Prerunner V6 DCSB. One in the middle, one on each side on the cab side. All 3 are about 1.5 inches back from the cab inside the bed.
  8. Jun 4, 2017 at 1:43 PM
    #68
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  9. Feb 22, 2018 at 3:19 PM
    #69
    MatrixDJ
    MatrixDJ New Member
    Michael
    Las Vegas
    2017 Silver Tacoma Off-Road 4x4
    Rough Country Nerf Steps, BFP Custom Toyota Grill, Dog Platform, Blacked out emblems (5hp ea.)
    Very nice! Thank you!
  10. Oct 2, 2021 at 5:35 PM
    #70
    Tacomamby4x4
    Tacomamby4x4 Well-Known Member
    Matthew
    06 Tacoma trd off road 4x4
    Lifted on 33s
    Need to do this in the near future
  11. May 29, 2022 at 9:40 PM
    #71
    ToyoTX85
    ToyoTX85 Well-Known Member
    I just did this very good and cheap mod to deter possible thief's . Super easy to do , btw the hole is 1/4 in case someone need to know .
    thanks to the OP :bowdown:
