quick box design question
Discussion in 'Audio & Video' started by Jpf8653, Nov 22, 2011.
  1. Nov 22, 2011 at 11:23 AM
    Jpf8653
    Jpf8653 [OP] Well-Known Member
    Justin
    Baton Rouge,LA
    Revtek 3" lift, Tinted Windows Wheels n' Tires Door Sill Protectors Rockford fosgate P3 shallow w/ alpine mono 500 amp in a MR MARV PORTED box Weathertech floor liner Rear TSB Pioneer 3200BT Double Din touch screen
    If a ported box is built with the airspace recommended in its design for a specific sub. no matter what sub. is that considered tuning the box, or is tuning a ported box a complete different animal on top of airsapce?
  2. Nov 22, 2011 at 12:19 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '06 DC LB 4x4
    OME lift w/ Dakars & 885's Remote Start w/ window control
    Grammar check??
    I think you're asking if a pre-built ported box is designed for a specific sub or not... maybe I'm wrong but the answer is no, a pre-built ported box is generic in size, with the idea that it will work for a large number of woofers.
    Tuning a ported enclosure (IMO) is designing a port (round) or vent (rectangular) that is tuned to give higher output at a specific frequency, which is also completely independent from the air space requirement for the sub.
    I could be wrong, and I welcome corrections.
  3. Nov 22, 2011 at 12:26 PM
    Jpf8653
    Justin
    Baton Rouge,LA
    Ok no I'm asking something different. My box was built with my sub in mind. The cubic feet internally for ported enclosure(given from manufacture) was used to build the box. So on top of that What does tuning do? Or is the box "tuned" already? Mr Marv built
    It.
  4. Nov 22, 2011 at 12:28 PM
    Jpf8653
    Justin
    Baton Rouge,LA
    Ok forgive me I see what ur saying. Air space is there and the port has to be tuned. Both play a role and or seperate from one another.
  5. Nov 22, 2011 at 12:47 PM
    TurboGT
    Gabe
    Portland
    '06 DC LB 4x4
    if the box was built from the manufacturer spec sheet, then your box is most likely tuned already.
    Again....
    Yes, they both play a role in how the sub is going to perform, but they are also seperate and independent of each other
