Quick clutch question
Discussion in '1st Gen. Tacomas (1995-2004)' started by lve2xlr8_mph, Oct 19, 2010.
  1. Oct 19, 2010 at 11:53 PM
    lve2xlr8_mph
    lve2xlr8_mph [OP] Silver Machine
    Tyler
    Zebulon, NC
    2004 Tacoma 3.4 V6 Limited
    Bilstein 3" lift
    Hay guy i got a quick question, ive got a guy thats wants me to change out his clutch and pressure plate, on a 2000 2wd V6. My question is how long should it take to change that, and is it real difficult. Ive changed out clutches before but only on FWD.
    Thanks
  2. Oct 20, 2010 at 9:06 AM
    lve2xlr8_mph
    Tyler
    Zebulon, NC
    Bilstein 3" lift
  3. Oct 20, 2010 at 1:21 PM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    I can't imagine that it would take any longer than the 4wd... no transfer case and extra weight to wrestle with.... Still probably wouldn't hurt to allocate a full day to get her done.
  4. Oct 20, 2010 at 1:23 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    You should do a write-up.
  5. Oct 20, 2010 at 5:12 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    If you plan on a couple of hours.... it will take all weekend. If you allocate a full day then it will take a few hours to change it out and the rest is good beer drinking time.
  6. Oct 21, 2010 at 8:21 AM
    lve2xlr8_mph
    Tyler
    Zebulon, NC
    Bilstein 3" lift
    Well what i was tryin to fig. out was how much im goin to charge this guy. He wants an estimate before i start, and ive never done a rear wheel drive before. ive only done front wheel drive.
  7. Oct 21, 2010 at 8:29 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Someone on this forum did it in his garage without a lift. I believe he said actual wrenching time was around 7 hours.
  8. Oct 21, 2010 at 8:31 AM
    lve2xlr8_mph
    Tyler
    Zebulon, NC
    Bilstein 3" lift
    Yea ive tryed lookin for one i fig. someone has done one but i havent seen one yet. Thanks that give me a better idea then than a whole day.
  9. Oct 21, 2010 at 10:01 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I didn't know that double cab tacomas came with a standard tranny? Or is it another truck? Not the one in your sig.
  10. Oct 21, 2010 at 7:31 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    He said it's for a friend
  11. Oct 21, 2010 at 10:26 PM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    took me 4 hours to change mine. But I had help from a friend and we had a lift also. pretty easy really, but the lift makes it soooo much nicer than laying on the ground. If I were to charge someone, I would charge about 200 bucks labor. Thats just me though. Find a friend that wants to learn how to change one though to help you free of charge!!!!!! It helps with the grunt work of the tranny/transfer case. Hope that helped. Oh..... just thought about something..... You will have to take out 4 little bolts that hold a "dust cover" on that is located I believe between the flywheel and the bottom of the bellhousing where they butt up together...... they are a PITA to get to. You will be cussing heavily by the time you get them back in after you're done. Good luck.
