Quick Connect Cables - Who has em?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by itsmemattp, Nov 17, 2014.
  1. Nov 17, 2014 at 9:15 AM
    itsmemattp
    itsmemattp [OP] Well-Known Member
    Ashland, Oregon
    06 Tacoma Access Cab 4x4
    Howdy, I've noticed that a lot of the city trucks as well as the state troopers around have quick a quick connect socket for easy access to jumper cables. Does anyone on here have one, or any experience? I think wiring one up for the front and rear would make it really handy to help out buddies and stranded randoms.
    Don't know if I just like the novelty or how much it would really come in handy but I thought I would see what you guys think.
    http://www.hardworkingtrucks.com/quick-connect-jumper-cables/
  2. Nov 17, 2014 at 9:29 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I know some have them for their winch connections for the front and rear. But if your driving your vehicle everyday you shouldn't have to jump someone that often. IF you are though, you can buy a battery pack, that you keep charged in the truck for times where it isn't possible to boost them in a traditional manner.
    Did this with my GF's old car, just used the battery pack to boost her, instead of fussing with cables. Used something like this
    I don't know how often your jumping cars though
  3. Nov 17, 2014 at 9:33 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    I have used them on tow trucks for years,nice at the time,but now everyone just uses jump boxes,portable,convenient.
  4. Nov 17, 2014 at 10:25 AM
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    I have one on my work truck, went to use it one day and it didn't have a good connection so I just propped the hood and did it the old fashioned way. Its kind of neat but just difficult keeping the connector away from the elements.
  5. Nov 17, 2014 at 10:30 AM
    Pigpen
    Dan
    Northwest Montana
    I have them front and rear. Never used for jumping, but nice for the winch.
  6. Nov 17, 2014 at 11:02 AM
    Tusk
    Tusk Active Member
  7. Nov 17, 2014 at 11:02 AM
    itsmemattp
    Ashland, Oregon
    Is it the same connection for the winch? I was curious, I am drawing up plans to have a hitch mounted winch and the cables would be neat to have if they drew off of the same plug.
