Quick disconnect sway bar
Discussion in 'Suspension' started by Polowhitfoot, Nov 18, 2008.
  1. Nov 23, 2008 at 7:33 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    that shouldnt be an issue...lots of people disco them for wheeling and then reattach
  2. Nov 23, 2008 at 7:44 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    alright, thanks guys.
  3. Mar 25, 2010 at 6:53 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
  4. Mar 25, 2010 at 6:55 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    It would work good on a solid axle, but doubt would help with IFS.
  5. Mar 25, 2010 at 7:37 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Good for an experiment but you'll definitely want to zip-tie the disconnected end link back to the swaybar or it will get f'ed up.
  6. Aug 22, 2011 at 1:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It works the same, IFS of solid axle. All the sway bar does is limit the opposite direction travel of each wheel.
    Removing the sway bar mounts from my truck is easy, takes like 5 minutes with the stock parts. The thing I've never really worked out it what to do with the sway bar once I've disconnected the two sides. I'm not going to remove the WHOLE thing, but I don't really want to just use a bungie to hold it up out of the way...
    IMO, taking the sway bar completely off is completely dumb if this is your daily driver. I've never had to use my airbag or my ABS, but I'm not about to disconnect a piece of safety equipment just because I haven't used it (yet).
  7. Aug 22, 2011 at 1:16 PM
    jbrandt
    Justin
    depending on what side you're testing... If you disconnect the left side, don't stuff the left wheel, and let the right side droop. You'd want to make sure the sway bar would move away from the control arm/spindle you disconnected.
    But yes, DEFINITELY only for a quick experiment, I wouldn't drive it like that.
  8. Sep 15, 2011 at 8:34 AM
    Rob2.7Taco
    Rob2.7Taco Well-Known Member
    Rob
    Bay Area, CA
    2010 Tacoma Prerunner
  9. Dec 5, 2012 at 5:45 PM
    MxJx
    MxJx Member
    Marcus
    Palm Beach
    95 Taco 6" Fabtech 3" BL
    6 Inch Fabtech 3" BL 37 inch tires Roll Bar and Lights
    X2
  10. Jul 4, 2015 at 7:45 PM
    sddarkman619
    sddarkman619 Well-Known Member
    Larry
    San Diego
    2015 Tacoma Sport TRD
    None(Yet)
    I had a set of these from Lars Dennert, very nice to have for sure, but I wish I could have them for my 2015 taco...
  11. Apr 12, 2016 at 10:24 PM
    kenn72
    kenn72 Member
    Philadelphia, PA
    10 DCLB SR5
    Bilstein 5100 adjustable front shocks + drivers side lean spacer, Bilstein 5100 rear shocks and Toytec AAL, LED interior lights, rear diff breather, anti dark under hood LED's, Redline hood struts, Uniden 520 CB, custom "fabricated" removable tool chest, 265/75R16 MTs + full size spare, Body Armor Sport Rack w/ KC HiLites 5" Apollo Pro lights
    Anyone out there have any info on a set of these for a 2gen dclb? Installed bilstein 5100's on my 2010 dclb and was planning on ditching the sway bar, but my guru suggested getting a set of quick diconnects as this is my daily driver. Ran into original equipment issues (stripped allen heads) and eneded up sawing them off. Can't seem to find them anywhere. TIA
