Quick Foglight question
Discussion in 'Lighting' started by taco2408, Jan 11, 2010.
  1. Jan 11, 2010 at 2:12 PM
    taco2408
    taco2408 [OP] Well-Known Member
    Marcos
    San Antonio, TX
    08 PreRunner DoubleCab
    If my truck is already prewired for foglights do I still need to buy the foglight relay? I was going to purchase some foglights off ebay and then get the oem switch but wasn't sure if I needed the relay. Thanks.
  2. Jan 11, 2010 at 2:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You will need the Relay, and a fuse.
  3. Jan 11, 2010 at 2:28 PM
    taco2408
    Marcos
    San Antonio, TX
    ok..thanks
  4. Jan 11, 2010 at 2:34 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    You may want to see the Fog lights ON write up in the cheap mods.
    Check to see if the fuse box has the empty spot where the relay would have been if factory installed. Plug yours in there and fallow the wire under the dash and install your switch.
    Take care
    vbibi:(
    PS Never know, the relay may be there to.
  5. Jan 11, 2010 at 9:01 PM
    taco2408
    Marcos
    San Antonio, TX
    one more question...will the ebay fog lights plug into the factory harness or will i have to use the one that comes with the lights
