Quick frame question
Discussion in '1st Gen. Tacomas (1995-2004)' started by the408taco, May 17, 2010.
  1. May 17, 2010 at 12:34 PM
    the408taco
    the408taco [OP] Active Member
    Nick
    San Jose
    97 4x4 Taco SR5
    K&N intake, flowmasters, rancho 5000's, american racing 18's wrapped in BF Muds, WAGG bumper guard w/ some hella head lights
    I have a 97 sr5 4x4 xtracab taco and Im trying to purchase a new frame. I found one but its a 2003, the guy says there the same from 95-2004 is this true?
  2. May 17, 2010 at 4:17 PM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    nothing? nobody's sure if a 2003 frame is the same as a 97?
  3. May 17, 2010 at 4:43 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    I think the frames are different. I don't know what is different though. The only reason I believe they are different is because:
    There was a buy-back program for model year 95.5-00 because there weren't any frames (or not enough...unsure of the specifics). For 01-04 however, there is a frame replacement program.
    I am sure some other folks will chime in soon.
  4. May 17, 2010 at 4:55 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    Why are you buying another frame?
    Rusty???
    If so, let Toyota buy your truck and go out and get another truck.
    The bill for my frame replacement was over $11,000.
    Going to be expensive for you.
    If the frames from 2001-2004 would work under the 1995.5-2000 trucks, I think Toyota would be using them and they aren't.
  5. May 18, 2010 at 11:09 AM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    No not any rust issues just a 4 inch dent on the passenger rail about a foot back from the front right tire. So nobody believes their identical? I think they have the recall for 95-2000 because of age. I don't believe the frames after that could have a rust problem, get what I'm saying?
  6. May 18, 2010 at 11:13 AM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    No... the frames after 2000 do have a rust problem.
    That's the reason for the frame replacement program.
  7. May 18, 2010 at 12:03 PM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    ok so i'm confused... basically the guy I am talking to telling me that the 95-2004 frames are the same is a liar??? theres no compatibility?
  8. May 18, 2010 at 12:28 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The general / overall key dimensions for an XtraCab frame are the same from 1995.5 through 2004. In this very general sense - yes, they're 'compatible'.
    However ...
    Certain mount and crossmember locations vary with engine and transmission type. Certain suspension attachment points / locations are different between 5-lug and 6-lug models. So it's not the case that just any 1995.5 - 1997 XtraCab frame can be replaced 'as is' by just any 2001 - 2004 frame.
  9. May 18, 2010 at 12:52 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    He may be stretching the truth to sell you a frame.
    Think about it.
    Do you think Toyota would be doing a buy-back program (KBB at 150% excellent condition, no matter what shape they are in) if they could just slip another frame under the 1995.5-2000 trucks?
  10. May 18, 2010 at 2:42 PM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    no I get what ur saying gusotto. He has a 2003 xtracab. I get the whole rust issue but my frame has no such problem... just a big ass dent....:-/ I apperciate it enolagaia.. so if his is a xtracab and had the same tranny and same size engine it should work?
  11. May 18, 2010 at 11:55 PM
    Firemedic269
    Firemedic269 Member
    2003 Tacoma Ext cab TRD
    Rust or not they might still buy your truck back because toyota effed up with the rust thing. I have a 2003 which is in right now getting a brand new frame along with a bunch of other stuff on toyota's dime. I'm not even paying for the loaner. I say it's worth a shot.
  12. May 19, 2010 at 5:56 AM
    Whitfield
    Whitfield Well-Known Member
    Central Virginia
    99 TRD X-cab on 35's / 96 X-cab on 33's
    Selling my 96 Tacoma to fund the FJ80 build up.
    408 never mentions rust... other then to say " NO RUST!!! Drop the rust ~ his truck was crashed and Toyota is not gonna help him.
    From my frame swap on my 99 x-cab..
    ~ The big difference as I understand it is that the 95-97 use shorter rear springs then the 98-2004.
    Their were also some minor changes with the front frame tube cap / bumper mounts.
    If you can over come the rear spring legnth and the engine and trans are the same as your truck then you can make it work.
    1. How much of the passenger side frame rail do you need? (I have one)
    2. I have a pair of 99 rear springs too.
    *** I could do either for $50 + shipping but the ugly part is I'm in VA and shipping large metal parts across the country is expensive.
    *** and as EnolaGaia says they gotta be 6-lug (4wd or pre runner) if yours is 6-lug ~ and frame needs to match engine and tranny combo.
  13. May 19, 2010 at 5:57 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    If they're both the same truck type (5-lug vs. 6-lug) and cab type (XtraCab) the frame should be compatible. If the very same engine / tranny was used in both trucks, the associated mounts should be the same.
    However, you may still need to do some modifications for suspension mounting locations / positions.
    In particular, check the rear leaf spring area. 1995.5 - 1997 Tacos have different length leafs than later ones.
  14. May 19, 2010 at 8:59 AM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    You guys r the shit! My frame is basically creased right behind the engine, I'll try n take some pictures I'm not sure how to get them on here though... I appriciate evrything I'm going to check it all out today.
  15. May 19, 2010 at 2:30 PM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    Alright so dude told me it had a v6 with a auto transmission. I got the 2.7 with a auto tranny. Would it be a pain in the ass to make it work? thanks again
  16. May 19, 2010 at 4:24 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    You'd have to re-do the motor mounts. I'm not sure about the transmission mounts.
  17. May 20, 2010 at 4:05 PM
    the408taco
    Nick
    San Jose
    97 4x4 Taco SR5
    yeah seems like my best bet would be to just wait until I find a same year model with same engine and tranny. What a pain in the ass...
