Quick Help!!! BrakeSiezed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by belone12, Feb 15, 2013.
  1. Feb 15, 2013 at 5:09 AM
    belone12
    belone12 [OP] Well-Known Member
    Brian
    Long Island, NY
    06 Tacoma Double Cab 6spd TRD OR
    Bilstein 5100s, AAL, heated leather seats, Thule Rack, tow package, anytime foglight, Fold-a-cover
    Guys I am on my way to mt Washington and the steering wheel starts shimmying. I pull over and the front left brake is locked on. I can't get it to release. I just jump started the truck bc the battery died when I got gas. Need help/ideas. In massachussettes
  2. Feb 15, 2013 at 5:11 AM
    belone12
    Brian
    Long Island, NY
    In auburn, mass
  3. Feb 15, 2013 at 5:27 AM
    ANGUS
    ANGUS Well-Known Member
    Beckley, WV
    06 SR5 4cyl
    3in rough country, front adj bilstiens 5100s, volant cold-air intake, magnaflow exhaust, optima yellowtop, 4.56 motive gears rear, 4.56 nitro gear front with v6 front diff carrier, brute force fab front bumper, 6k hid, 1.25" wheel spacers, 15% window tint, cab lights, color matched bushwackers, trd hood
    hard to say why without seeing. maybe brake pad or caliper piston fell apart and lodged? maybe wheel bearing?
  4. Feb 15, 2013 at 5:29 AM
    belone12
    Brian
    Long Island, NY
    This ever happened?
  5. Feb 15, 2013 at 5:39 AM
    belone12
    Brian
    Long Island, NY
    I am at sears now getting a new battery. There was one fortunately under a mile. I can't tell of the brake released but of course no one here will just look at it.
    I don't think its the bearings, the actual pad was locked on when I pulled over
  6. Feb 17, 2013 at 3:57 PM
    romafern
    romafern Well-Known Member
    Rob
    Olympia, WA
    stock and very pissed about the issues
    Machine gun mount. Would love to blow the shit out of it since it has nothing but issues. QA at Toyota USA is shit. Start making them in Japan for Christ's Sake!
    So what happened? You got it fixed now?
  7. Feb 17, 2013 at 6:08 PM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    If I was on the road and couldn't get the truck into a warm shop, I'd try using a car wash wand to thaw out the hub area and flush whatever garbage I could out of the caliper and carrier.
    The caliper really needs to be pulled loose and inspected. More than likely, the caliper isn't freely floating in the carrier frame. Cleaning and lubing it may work, but if it got this bad, don't be surprised if some parts need to be replaced due to corrosion.
  8. Feb 17, 2013 at 6:17 PM
    belone12
    Brian
    Long Island, NY
    Nail on the head. It's a Long story to write, but it released while I was at sears getting the new battery put in. Another customer there so my irritation and asked whts up. He highly recommended a local mechanic in Worcester, MA - D.T. Automotive. These guys were awesome and yes the caliper was bad and told me it would just happen again. 1.5 hours later (had to wait or prt delivery) I was back on the road. They were very understanding of my situation and hooked it up price wise.
    So hopefully now I am good to go. But the money I spent on the caliper and battery sadly came out of the hard tonneau fund. Oh well.
    Thanks for following up though.
  9. Feb 17, 2013 at 6:30 PM
    DoorDing
    Bodie, CA
    yes
    Good to hear. That's a very fast turnaround for an unscheduled shop visit.
    If you haven't already, I suggest changing your brake and clutch fluid every two years. It'll prolong the life of those systems as well as make the brakes perform better. Aside from the corrosive properties of fresh brake fluid, accummulated water and wear debris will chew up the hydraulics.
  10. Feb 17, 2013 at 7:08 PM
    belone12
    Brian
    Long Island, NY
    Thanks bud i appreciate the tip. I just bought it in august from a wholesaler so I have no idea what kind of maintenance the last owner did. Kindof starting from scratch in all areas (@ 82k miles).
    The guys in the shop were awesome.
  11. Feb 17, 2013 at 7:13 PM
    DoorDing
    Bodie, CA
    yes
    Best off assuming all the fluids are bad and change them soon. Even if uncontaminated, they're probably worn out OEM fills. Hopefully, that doesn't apply to the engine oil. :)
  12. Feb 18, 2013 at 4:42 PM
    belone12
    Brian
    Long Island, NY
    1st thing I did when I brought her home was an oil change, that uneasy definitely not going to guess on. Thanks! I will look into the others. I plan on teaching my unborn son to drive in this truck so longevity is key!
