Quick help installing bump stops and rear extended brake lines
Discussion in 'Southern California' started by PJTree, Jul 26, 2022.
  1. Jul 26, 2022 at 8:50 AM
    PJTree
    PJTree [OP] Well-Known Member
    2017 White Tacoma TRD 6SPD
    Hello,
    I am in a bit of a pinch here and need some help. I have a set of Timbren bump stops and rear extended brake lines.
    Would anyone be able to assist with the installation this Thursday? I am located in Irvine but will drive up to an hour 1-way. I will be going on a trip Friday...
    Compensation as well as food/drinks are on the table.
    Thanks in advance!
    PJ
  2. Jul 26, 2022 at 10:44 AM
    NACAircrew
    NACAircrew Well-Known Member
    My pronoun is Chaz
    TRD OR/4R Trail
    Raptor lights/Meso everything/Predator steps
    I think you need a flare nut line wrench for the brake lines....maybe i'm wrong.
  3. Jul 27, 2022 at 6:05 PM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    @PJTree are you wanting to do this because you already have suspension installed that warrants longer brake lines?
  4. Jul 28, 2022 at 7:34 AM
    bprout
    bprout Well-Known Member
    Brian
    SoCal
    2014 SR5 4x4
    Runs off Hopes and Dreams
    This is correct - 10mm flare nut wrench - or else you might strip the nuts that hold your break lines on.
