Quick Help please! (headlights)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tombiosis, Feb 22, 2012.
  1. Feb 22, 2012 at 7:52 AM
    tombiosis
    tombiosis [OP] Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Hi
    I am trying to switch out my lamps for my modded bhlm ones. The ones I modded came without the big rubber plug thingy that seals in the main bulb.
    I have the headlight out and want to install the bhlm one onto the truck...how do I get that big rubber thing off the stock lamp to install onto the new lamp?
    links with pics?
    (I searched all the bhlm threads and no one mentions this step,,,
  2. Feb 22, 2012 at 7:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If its the rubber seal on the back of the bulb, it should just pull off.
  3. Feb 22, 2012 at 7:57 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    The rubber boot should just pull out of the OEM headlight assembly, there's nothing keeping it attached other than a tight fit. You need to pull it out in order to change the bulb.
  4. Feb 22, 2012 at 7:58 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
  5. Feb 22, 2012 at 7:58 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  6. Feb 22, 2012 at 8:00 AM
    tombiosis
    T
    Ottawa Canada
    thanks guys!
    I guess it was just stuck after being on there so long...
    I got it now and am off to finish installing my bhlm's!!!!
    :woot:
    :canada:
