Quick HELP! Truck won't go past 2500 rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stompson, Apr 7, 2024.
  1. Apr 7, 2024 at 12:24 PM
    Stompson
    Stompson [OP] Well-Known Member
    VA
    2017 TRD Sport Short Bed MT
    OME Lift > Stage 3 ICON, KDMax Pro Tune Leitner ACS, Decked Box
    My son is driving back to Military College from Va to Ga. He's currently near Columbia, SC. He just refueled and said that when he got back on the road his truck refused to go past 2500 rpm. He's got no check engine lights, no stuttering...just sounds like it's hitting a rev limiter. He said the intake/exhaust seems normal. It WILL rev past 2500 in Neutral or Park. He's able to reach highway speeds, but it obviously takes even longer than normal with the RPMs so low. Looking for some quick defferential diagnosis, and maybe some quick checks he can perform while he's on the road.
    It's a 2010 V6 Auto, 4wd Base model w/offroad package.
    Thanks
  2. Apr 7, 2024 at 12:44 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Has he shut it off and restarted it?
    Best I got.
  3. Apr 7, 2024 at 1:13 PM
    Stompson
    VA
    Yeah, I believe so. He's planning on stopping again in about 1.5 hours for dinner. I'll have him try and unhook the negative battery terminal for 10-15 minutes to see if it helps.
    Jeffch[QUOTED] likes this.
  4. Apr 7, 2024 at 1:18 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    If he finds an open auto parts store a lot will scan for codes for free.
    Maybe check the gas cap?
  5. Apr 7, 2024 at 5:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is his ABS light on by chance?
  6. Apr 7, 2024 at 6:36 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    I'm not sure about Toyota's, but my wife's CX-5 went into the limp mode from a loose negative cable and then later a weak battery.
    Although, she had almost every check light on her intrument panel light up as well.
    Once each was corrected her vehicle ran fine.
    Hopefully it'll be that simple for y'all.
  7. Apr 7, 2024 at 7:43 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Clean the throttle body and sensor.
