Quick jolt/loss of power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lolwordde, Jan 2, 2018.
  1. Jan 2, 2018 at 12:51 PM
    Lolwordde
    Lolwordde [OP] New Member
    Nick
    2008 Red Toyota Tacoma
    Cold morning, truck didn’t quite want to crank.
    Riding down the road going around 60 and a sudden jolt went throughout the truck. Radio went off, dash lights came on.
    I put the truck into neutral and coasted to the side of the road (truck is still running by the way). All the lights went back off right as it happened and the radio came back on.
    Any ideas as to what this might be? There is corrosion on my positive battery terminal. Just wondering if that could be the cause or if it might’ve been something else?
  2. Jan 2, 2018 at 12:55 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    UFO's
    BassAckwards likes this.
  3. Jan 2, 2018 at 12:56 PM
    Lolwordde
    Nick
    I’m starting to believe the same thing.
  4. Jan 2, 2018 at 1:07 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Gotta start somewhere ,might as well clean both terminals,and follow the ground wire and clean at every junction and termination.
  5. Jan 2, 2018 at 1:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes, clean battery connections, check grounds on frame and engine, check alternator perf.
    Ignition switch may be going bad too. Slowly turn the key through the different positions (lock,acc,run,start) while wiggling/jiggling the key. The dash lites/power will come and go if the ign switch contacts are starting to fry
  6. Jan 2, 2018 at 10:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Maybe I'm dumb or slow or ... I have been driving various vehicles since I was 15 years old ( now really close to 63 years old ). Other than the connection at the battery terminal I have never seen a loose or high resistance ground connection on any vehicle. Of course that wouldn't include one that has been loosened by a mechanic and not tightened properly after. Why does lots on here always recommend checking and cleaning the ground connections on the body, chassis etc... Honest question. Have you ever found a defective ground connection on the chassis or body?
  7. Jan 2, 2018 at 10:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yep, my 87 supra ate 3 alternators before i found/tightened the loose battery cable down on the frame below the battery tray. My dad's 2nd gen had a battery warning lamp that would come and go randomly, the alternator would stop charging. I threw a couple alternators at that one too thinking I got 2 bad remans in a row. I found the little 10 mm nut on the positive cable post in the fuse box (near the main fuses) had backed off. Tightened the nut, never saw the battery light again
