Quick Lesson when buying a USED vehicle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeratbp, May 29, 2012.
  1. May 29, 2012 at 7:25 AM
    jeratbp
    jeratbp [OP] Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
    CHANGE the fluids!
    I bought my '08 roughly 3 months ago with 42,000 miles at Carmax. This past weekend I changed my oil & filter, and the air filter. Then I changed the front and rear differentials. Also, I am NOT mechanically inclined - still learning. So choose what brands you like.
    OIL/AIR: Dealer had put in whatever bulk oil & filter they use. The filter was awful, though I didn't break it getting it off. I replaced it with a K&N filter and Pennzoil. Air filter was also replaced with a K&N. Expensive, but I thought worth it.
    DIFFERENTIAL: The 24mm and 10mm plugs were so tight that I guess the previous owner never had changed the fluid. The smells weren't aweful, but both were completely black. I replaced the fluid with the Mobil 1 Synthetic 75w-90. I did use the Pump for both the front and rear.
    TRANSFER CASE: Had I read about this before hand, I would have replaced it at the same time. So now I know what I'm doing next weekend.
  2. May 29, 2012 at 7:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I use Toyota oil filters, Mobil 1 Synthetic 5W-30 for the engine and currently have an STP air filter but will go back to Toyota once I can pick one up.
    I can't remember what I used for the differentials but I don't believe I used synthetic.
    Truth be told, as long as it's the correct weight oil and a reputable brand, you'll be fine. Chris4x4 did a write up where he tested a bunch of oil filters side by side (cut them open to inspect the insides). Turns out, the OEM filters are among the best you can buy for the Tacoma.
  3. May 29, 2012 at 7:31 AM
    evh5150
    evh5150 Well-Known Member
    Eddie
    Auburn,Ma
    2010 D/C S/B V6 6 Speed
    Bilstein/5100 combo from Toytec. LR UCA's.1.5 AAL's Full audio upgrade.Pioneer 8400, JL Audio subs. All Boston Acoustic pro speakers, and a Kenwood XRS 5 amp. Grillcraft, Smittybuilt stainless steps. Debadged. Soon 17x8 ATX Ledge wheels w/285/70/17 BF Goodrich
    Pugga wiz uppppppppppp
  4. May 29, 2012 at 7:35 AM
    Pugga
    Massachusetts
    Livin' the dream :D
  5. May 29, 2012 at 10:12 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    nice.
    i would have used OEM filters for both Air and oil.
  6. May 29, 2012 at 10:17 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Uhhh...I bought my 2010 4x4 from CarMax with 51k on it. I've put 3k on it so far, and so far, she's running perfectly fine...do I need to change my diff oil?
  7. May 29, 2012 at 10:18 AM
    Pugga
    Massachusetts
    If you don't know the service history then it would be a good idea to change the diff fluids, x-fer case fluid and spark plugs.
    Oh yeah, OP, change your spark plugs also!
  8. May 29, 2012 at 10:20 AM
    The Traveler
    SoCal
    Is there a write-up on changing the diff and transfer case fluids? I'm pretty mechanically inclined, but I'm sure it'll be easier with a guide.
  9. May 29, 2012 at 10:22 AM
    Pugga
    Massachusetts
    X-fer case DIY and in the first post there is a link to a rear diff DIY.
    http://www.tacomaworld.com/forum/2n...ront-diff-transfer-case-oil-change-howto.html
    Helpful hint - Make sure you get the fill plug loose before you drain the fluid out. If you drain the fluid and the fill plug ends up being stripped so you can't get fluid back in, you'll be calling for a tow.
  10. May 29, 2012 at 10:23 AM
    The Traveler
    SoCal
    Just saw that actually, haha thanks.
  11. May 29, 2012 at 10:30 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    This is normal now. Dealers do nothing to used cars except wash and wax. Days when Certified Pre-Owned meant all fluids replaced, all filters replaced, alignment done, wheel rebalanced check done are over. If you buying used vehicle expect to drop extra money right a way to get things replaced unless vehicle is less then 3 years old.
  12. May 29, 2012 at 11:03 AM
    jeratbp
    Jeremy
    Norfolk, VA
    Pugga - thanks for the reminder. I'll go check out the How To for the Spark Plugs.
