Quick Level/Tire clearance question
Discussion in 'Suspension' started by JHart94949, Aug 27, 2014.
  1. Aug 27, 2014 at 8:57 AM
    JHart94949
    JHart94949 [OP] Well-Known Member
    Joe
    NorCal
    2013 TRD Off Road
    Pro-Comp Leveling kit
    I know this has most likely been asked and answered but I don't have time to look/search all the forums while at work.
    I am installing a pro comp leveling kit (2.25") on Tuesday. I was going to order Hercules Trail Gripper M/T's, 285/75R-16's but after reading some posts I am a little worried that I am going have major rubbing issues.
    I don't do any hard core off roading, my truck does see some "off road" when camping and hunting but I am not crawling over boulders or anything, mainly dirt/mud uneven roads with drainage ditches dug through them.
    SO....will I have any issues with the above set up? Again I apologize for asking a question that I am sure is in here somewhere but truly appreciate your help.
  2. Aug 27, 2014 at 9:00 AM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    so you dont have the time to search but to type all this? Anyway your answer is that you will more than likely have issues. especially at only 2.25". you will just have to do a lot of cutting and trimming
  3. Aug 27, 2014 at 9:07 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    You'll probably have to remove the front mudflaps, maybe the rear mudflaps too.
    The biggest problem I think you'll have is that the 285's will be too wide to clear the UCA without any wheel spacers, unless you're putting them on wheels with at least 4.5" backspacing.
