Quick lift idiot check - '21 DCLB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by escapethewormhole, Feb 1, 2021.
  1. Feb 1, 2021 at 6:51 PM
    escapethewormhole
    escapethewormhole [OP] Member
    Edmonton, Alberta
    So I'm new here, searched extensively and found lots of bits and pieces of information on a somewhat cost effective setup using bilstein 5100's. But mostly the info seems to be for 2nd gens and earlier.
    It sounds like I should avoid add a leafs, and go with a full leaf pack.
    I will be doing 99% on pavement driving. This is mostly for look but I'd rather build for function than save $400.
    Here's what I have in my cart and I could use a quick idiot check before I go and order and back myself into a corner.
    Truck is a 2021 TRD Sport Premium Double Cab.
    JC713 likes this.
  2. Feb 1, 2021 at 7:10 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    What us your in basket total?
  3. Feb 1, 2021 at 7:18 PM
    escapethewormhole
    Edmonton, Alberta
    $1573.30 CAD
  4. Feb 1, 2021 at 7:28 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Great kit. As far as full leaf pack you definitely don’t need that for looks. Get yourself a 3 leaf AAL you will be good. I have a long bed with same lift.
    Good Luck OP
  5. Feb 1, 2021 at 7:34 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    AALs are fine. You just need to be careful, it's not that hard. Save a few bucks in my book.
    Your cart looks good to me for a better setup. Just double and triple check part numbers, I've saved my own butt a few times checking.
    71tattooguy likes this.
  6. Feb 1, 2021 at 7:34 PM
    Vo0Do0
    Vo0Do0 Well-Known Member
    2020 VooDoo Blue Tacoma TRD Off-Road
    IF you are trying to get the least expensive lift and will not go off pavement then you can do spacers in the rear. They will be fine for on-road only use.
    I do light off-roading so I went with an AAL in rear. Depends on your budget.
    I am not able to see what you have in your cart but $1500 sounds reasonable for a lift if it is an AAL.. seems a bit high if it is a block kit.
    71tattooguy and LoveableWerewolf like this.
  7. Feb 1, 2021 at 7:38 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    You need the UBOLT flip pad to go with the UBOLTs. Didn’t see them in the photo.
    also, I had AAL and it went flat so if you carry any weight then the leaf pack will serve you better
  8. Feb 1, 2021 at 7:39 PM
    Vo0Do0
    How much weight were you carrying? I researched a bit before I went that route and seemed to be good at holding up a RTT (with gear and stuff roughly 400lbs)
  9. Feb 1, 2021 at 7:41 PM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Chances are you will be upgrading to a full leaf pack in a year or so
  10. Feb 1, 2021 at 7:50 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    99% pavement. Depending how much lift you want. Get the bilsteins and coils and throw a 1” or 2” block in the back and call it day. Now if your planning on really going off-road then a progressive aal pack or the full pack would be the way to go for the rear. God luck.
    71tattooguy and whatstcp like this.
  11. Feb 1, 2021 at 8:54 PM
    Vlady
    Issy, WA
    Do the need bearing replacement the same time...
    gsubioguy likes this.
  12. Feb 2, 2021 at 5:51 AM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO2s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    You may want to consider Eibach coils. There have been many reports of the Ole Man Emu coils sagging on 3rd gens.
    Ehahn84, SpeySquatch and 71tattooguy like this.
  13. Feb 2, 2021 at 6:08 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4
    Overbuilt daily driver
    Dobinsons is another option. Shocks are reported to be smoother than OME, coils have a sagging warranty, and leaf packs are supposedly less squeaky than OME/Dakar. I only have ~7k miles on my Dobinsons setup, but it has been good so far.
  14. Feb 2, 2021 at 8:41 AM
    bolt_thrower77
    bolt_thrower77 Well-Known Member
    2021 DCLB trd or
    i was under the impression that all lifts need a new upper control arm and some kind of relocation kit......no?
  15. Feb 2, 2021 at 8:44 AM
    escapethewormhole
    Edmonton, Alberta
    It appears you only need UCA's if you're going over 2.5" in the front, same with the relocation kit.
  16. Feb 2, 2021 at 8:48 AM
    escapethewormhole
    Edmonton, Alberta
    I decided to go with the Eibach coils on your recommendation. They were cheaper anyhow and I've had good past experiences with the brand.
    I also just bought their block at the same time because it was only $90 and will give me the the 1" I need. If I end up seeing my suspension go flat or want more I'll change the rear springs later.
    IrishRed[QUOTED] likes this.
  17. Feb 2, 2021 at 8:55 AM
    bolt_thrower77
    2021 DCLB trd or
    i also believe that most lift jobs end up needing to "cab chop" or alter the wheel housing in some way to make room for all the bigger stuff
  18. Feb 2, 2021 at 8:55 AM
    EvilElvis
    EvilElvis Well-Known Member
    PNW
    2012 3wd
    If you do decide to go with the ome dakars, trim the second leaf so that they don't chew up your shackles
  19. Feb 2, 2021 at 9:07 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I am 2" in the front and 1.5" in the rear with stock UCA's and no sway bar relocation and have lots of clearance.
    JC713 likes this.
  20. Feb 2, 2021 at 9:10 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    If you're looking to save money I'd use the stock coil spring and an AAL. Otherwise looks good.
    VaToy and 71tattooguy like this.
