quick oil change question
Discussion in 'Technical Chat' started by stephenm, Jan 29, 2012.
  1. Jan 29, 2012 at 4:35 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    For easy access mount the spare with the valve stem facing down. Also, check this link out...
    http://answers.yahoo.com/question/index?qid=20070926014414AABEjZ1
  2. Jan 29, 2012 at 4:38 PM
    06 skytaco
    06 skytaco New Member
    phila pa
    06 tacoma trd
    after checking all pressures are the same.....make sure u drive it....has to see over 15 mph the reset itself....if still on u prob have a sensor goin bad in one of the tires....plus raise the spare a little higher sometimes helps since that tire does not heat up while driving......plus sometimes high pressures drive the system nuts....
  3. Jan 29, 2012 at 7:19 PM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Good call.
