quick oil filter question for 4.0L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by praetor, Dec 13, 2008.
  1. Dec 15, 2008 at 12:57 PM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    every 3 grand or 3 months new filter and oil. My friend only adds oil and changes filter every 3 grand, never changes his oil! I will never buy a car from him.
  2. Dec 15, 2008 at 1:30 PM
    Joe B
    Joe B Well-Known Member
    Nice design but $200!!!!:eek:
    I don't mind spending money on my truck but that's a bit over the top for a filter.
    I'll stick with Amsoil EA or a Napa Gold(Wix)filter.:)
  3. Dec 15, 2008 at 1:31 PM
    praetor
    praetor [OP] Well-Known Member
    Carlsbad, NM
    08 Prerunner Accesscab TRD Off Road
  4. Dec 15, 2008 at 2:13 PM
    sonjay
    sonjay Well-Known Member
    This is a very bad idea IMO. you would want to do it the other way around, change the filter every 5k and dump the oil at 10k. Once the filter is "full" it bypasses it all together. Not a good thing IMO.
    Those filter look like a neat idea. A little pricey for my application. However if I had a race engine worth big bucks I wouldn't hesitate to get one.
  5. Dec 15, 2008 at 2:19 PM
    praetor
    Carlsbad, NM
    Me too. If I had the money to buy a race engine I would have the money to buy that filter.
  6. Dec 15, 2008 at 2:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Everything I have reasearched on these, they are not as good as OEM.
    X2.
  7. Dec 15, 2008 at 3:40 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What?????? :confused:
    Why would you change the oil, but not the filter? You're just asking for trouble if you don't change the filter with the oil... if that's what you're asking. :cool:
  8. Dec 15, 2008 at 3:57 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^Plenty of folks who do extended drain intervals do that. They do an oil study every 5K miles and if they oil is fine, just swap the filter. Bobistheoilguy.com is filled with people who do this.
  9. Dec 15, 2008 at 5:00 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    The D1 is for the 4cyl
    The D3 is for the V6
    I went by the dealer today to buy some filters. I took the YZZD1 code and asked if it works on the 05 V6.
    I bought a case (10) 90915-YZZD3 Toyota Filters. List is $5.41 for 1 filter. You get a better deal when you buy more at a time. I got these for $43 ($4.30 each).
  10. Dec 15, 2008 at 6:38 PM
    sonjay
    You wouldn't happen to have a part number handy for these filters? Would it be the same as the Sequoia V8?
  11. Dec 16, 2008 at 4:00 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    if you shop around, you can find em for $125.
  12. Dec 16, 2008 at 6:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    RCBS, A friend of mine used one of those and ran a few tests. They dont filter down as low as OEM, despite their claims, and cleaning it was a PITA.
  13. Dec 16, 2008 at 11:12 AM
    RCBS
    i think 30 microns is what they claim. i've read K&N goes down to 10. dunno about the factory filters. i think the magnet is a major draw for me after seeing what my drainplugs looked like when i did the 30k fluid change. so i wonder if their higher flow rate claim is true or not?
    i figured the cleaning would be easy with some good solvent based brake cleaner.
    i just thought of something...we should probably be more focused on the fuel we use, and the AIR filter...these are the only two ways for dirt to get in, correct? passing through the air filter or from deposits the fuel leaves behind. rather than worry about which filters the oil the best, try to prevent dirt from being in the oil in the first place.
    am i onto something....?
  14. Dec 16, 2008 at 11:16 AM
    sonjay
    ^^Bingo I agree 100%. If you change your oil and filter regular, you won't have any problem even if you run the cheapest filter you can find. I personally don't like the idea of a magnet in my oil filter for the reason that there is a lot of fluid going through a relatively small area, good change that any metal on the magnet won't stay there long?
  15. Dec 16, 2008 at 11:17 AM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    your correct. The filter also filters parts that wear from inside the engine. the OEM filter is rated down to - 10 microns just like the K&N and Mobil 1 filters. Anything larger than 20 microns is determined to be bad for the engine. I think these filters are good for show cars or the like, but I wouldnt run one on my truck. Any filter I run MUST filter down below 20 microns. You could always affix a magnet to your filter, and you could make it removeable so it could be put on futer filters. Its not hard to do.
  16. Dec 17, 2008 at 11:03 PM
    #36
    genxer36
    Sean
    Bethlehem,GA
    And the OEM one costs $5.41, where Mobil 1 wants $12 bucks. And if you buy in bulk the dealer gives a discount.
