Quick question about a purchase, need help asap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slickrick0999, Jan 5, 2018.
  1. Jan 5, 2018 at 5:36 PM
    Slickrick0999
    Slickrick0999 [OP] Well-Known Member
    Rick
    2010 SR5 4x4 dblcab shorty
    Fixed console button Cabinet lock on panel under seat 2016 wheels
    Hello TW,
    I am buying some take off shocks and struts tomorrow. They are from a 2017 Tacoma OR. I have a 2010 Tacoma that I will be putting them on. The seller asked if I wanted the upper control arms as well (take offs).
    My question is, will the upper control arms work on my 2010?
    Thanks,
    Rick
  2. Jan 5, 2018 at 5:42 PM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
    I believe they should work for your 2010
    Slickrick0999[OP] likes this.
  3. Jan 5, 2018 at 5:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm like 99% certain they'll fit. Aftermarket UCAs are marketed as '05+ meaning they work on 2nd and 3rd gens, so I don't see why the factory ones wouldn't be the same.
  4. Jan 5, 2018 at 5:52 PM
    Slickrick0999
    Rick
    So, should I grab them as well? Any benefit in putting them on my old truck?
  5. Jan 5, 2018 at 5:54 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The only benefit is if your current UCAs are worn out and could use replacing.
  6. Jan 5, 2018 at 5:56 PM
    eon_blue
    Azusa, CA
    I don't think so...unless your stock UCAs have worn out ball joints that need replacing, then it would be worth it only if you're getting a good price on them. Aftermarket UCAs are usually designed to be serviceable and allow for more travel, and allow for better alignment numbers with lifted trucks. Stock UCAs don't provide any of that unless the 3rd gen ones are somehow better than the 2nd gens.
  7. Jan 5, 2018 at 5:58 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Your 2010 is NOT old.
    The control arms don’t really “wear out”. The bushings and such do. But if he’s giving you a good deal might as well. I’m starting to think about doing bushings on my 06’
  8. Jan 5, 2018 at 6:06 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahh semantics
    Tacotj likes this.
  9. Jan 5, 2018 at 6:10 PM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Grab them for spares.
  10. Jan 5, 2018 at 8:24 PM
    sdcrofts
    sdcrofts Well-Known Member
    Scott
    2015 Tacoma XSP-X
    OME 887; Bilstein shocks; LR UCA; Wheeler's AAL; Debadge
    If you give me 2 weeks you can have my struts, rear shocks, and upper control arms off my 2015 SR5 for cheap cheap cheap. (I'm not sure what a Tacoma OR is BTW, so maybe mine won't work for you.) Either way, LMK.
  11. Jan 6, 2018 at 12:09 PM
    dustin19d
    Dustin
    Washington
    LMAO
    EatSleepTacos[QUOTED] likes this.
