quick question about deck plate mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by da0023, Mar 22, 2010.
  1. Mar 22, 2010 at 9:36 AM
    da0023
    da0023 [OP] The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    doing the deck plate mod this evening, how long should a wait for the sensor safe sealent to sit before i try driving it? also can I use a regular air filter for this mod, or do I need to get a k&n or afe pro dry? thanks in advance.
    Drew
  2. Mar 22, 2010 at 9:52 AM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    You can use your regular filter, but I think it works best with an aftermarket filter. Not sure on the sensorsafe sealant because I used a rubber gasket instead. It should say on the sealant right?
  3. Mar 22, 2010 at 10:34 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    I did mine at night and left it until the morning, it's really not a huge deal though, your air box isn't sealed anyways. but overnight will suffice
  4. Mar 22, 2010 at 2:08 PM
    KentuckyTaco
    KentuckyTaco Well-Known Member
    P-Town
    02 xcab 4x4
    K&N filter w/deckplate mod Dynomax muffler Tinted windows Maglite mod Line-x spray in bedliner Blacked out taillights/3rd brake light
    I just left mine set for a few hours then put it back on..check engine light did come on afterwards but all I did was reset it. x2 on the air filter.
  5. Mar 22, 2010 at 3:58 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    i'll just let it set overnight just to be safe. while I was at the parts store I picked up a k&n.
  6. Mar 22, 2010 at 4:28 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (190k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ K&N air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    If you use sensor safe sealant you don't have to wait . . . that's the beauty of "sensor safe". When I did the mod I started my truck up and drove around after only the time it took me to re-install the airbox with no issues at all. Of course, if you have the time you certainly can't go wrong with waiting.
    Good choice on picking up the K&N - you're going to love the difference with new mod and filter!
  7. Mar 22, 2010 at 5:59 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    I drove it 20 min after putting it in no check light came on
  8. Mar 22, 2010 at 6:23 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    here's the final product w/ the k&n filter installed. can't wait til the morning to see if there is any difference.
  9. Mar 22, 2010 at 6:49 PM
    RPain
    RPain I drink, and I break things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    let us know how it is, i just got my deck plate in the mail today, picked up my sensor safe sealant and hole saw afe pro dry already in there
  10. Mar 22, 2010 at 6:53 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    I've noticed about 1-2 MPG better since I did the Deckplate. Great, cheap little mod. I drove my truck through some bad puddles in town the other day and check it afterwards and my air filter and everything was dry as a bone. Congrats.
  11. Mar 22, 2010 at 8:17 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    thanks for all the help guys ;)
