Quick question about duratracs in light snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lunercrab, Jan 7, 2011.
  1. Jan 7, 2011 at 4:38 AM
    Lunercrab
    Lunercrab [OP] AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    Hey guys. So I haven't been able to really test out my duratracs in any deep snow (3" +) yet but I have use my truck twice this year so far in light snow falls. Anyways are these tires better performers in deeper snow? I ask cause in the lighter stickier stuff they are good but not as great as I expected. Isn't the tread self cleaning? I ask cause by the time I get home there is so much snow caked into the tread throughout the tire u can barely see tread at all. Is this normal? Could it be I'm driving too slow for the tread to clean out? Or should I lower the tire pressure maybe? I'm running 30 psi. I'm just wondering if that snow in the tread could be why I seem to slide around alittle more then expected.
  2. Jan 7, 2011 at 5:08 AM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    Not sure about the self cleaning part with this tread, but a lot would depend on the snow consistency.
    In regards to the slipping and sliding, I put 4 70lb bags of sand in my truck bed which helped a lot.
    Alan
  3. Jan 7, 2011 at 5:36 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    I'm having no problem with mine. I'm running 32 psi in all four. If the roads are slick and you have no weight in the back and try to climb a hill you will spin if not in 4WD.
  4. Jan 7, 2011 at 6:43 AM
    Lunercrab
    Beth
    Yeah I have two 50lb bags of salt in the bed. Like I said don't get me wrong I'm getting around ok just not feeling that much of a "grip" on the road. I think it really could be the snow. It's a very wet easily packable type snow both times. Maybe that's why it sticks so well in the tread :)
  5. Jan 7, 2011 at 3:17 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Here are the duratracs in alittle more snow.
    As far as self cleaning, did you really expect nothing to stick to the tires??
    here is a pic afterwards in driveway, they look preatty clean there
    As far as sliding, Are you in 4wd when sliding around??
    these trucks back end is so light , its going to slide on any amount of snow.
    There is not enoungh weight over the rear tires to get a really good grip.
    you could put weight back there , but then your driving around all the time with the extra weight.
    Anytime the back end starts sliding around or not getting any good grip
    I put it in 4wd, and problem solved.
  6. Jan 7, 2011 at 3:24 PM
    WABOOM
    WABOOM Well-Known Member
    Minnesota yeah sure ya betcha
    2013 F-150 XLT Supercrew 4x4
    debadged
    I've been driving my Tacoma alot this winter and it is way fuckin better in snow than the Z71 Silverado I had last winter. I'm starting to think that lighter is better. In the Chev I put over 300 lbs of sand in the back and it still didn't have the traction that my Tacoma has with NO SAND
  7. Jan 7, 2011 at 3:27 PM
    musty40
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    Lunercrab,
    Maybe try some more weight. I know going from 140lbs to 280 made a difference for me. 100lbs is like having a little kid rolling around in the back.
    Alan
  8. Jan 7, 2011 at 3:32 PM
    skistoy
    Western New York
    I dont do any weight.
    When conditions call for it, aka - the back end starts sliding
    I put it in 4wd, you know, the reason i bought the truck.
