Quick question about the Satoshi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10PreRunner, May 17, 2010.
  1. May 17, 2010 at 1:05 PM
    10PreRunner
    10PreRunner [OP] Well-Known Member
    Kevin
    Knoxville, Tennessee
    2013 SR5 4x4 Double Cab
    I'm in the process of cutting my grill to do a satoshi. My question is does the mesh or grillcraft curve any or does it sit in from the back straight? Thanks for the help
  2. May 17, 2010 at 1:54 PM
    10PreRunner
    Kevin
    Somebody has to know the answer to this.
  3. May 17, 2010 at 3:28 PM
    jmcnair327
    jmcnair327 Active Member
    Baltimore
    05' Tacoma
    Just did mine last week....I used a grillcraft and it does curve a little in both directions. Its rolled outward in all directions from the center.
  4. May 17, 2010 at 3:31 PM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    ya it does not sit flush. Which bugs me a lot! If you buy the grillcraft grill I would suggest only using it to put it on the front of the grill...like how it is meant to be put on. I mean...I've had the grillcraft on my truck for almost a year now and I did the satoshi mod and it hasn't come off, nor does it even look un-even at all, but if you're one of those guys where something little can bug the shit out of you I would suggest just getting the grill from customcargrills.com. my .02
  5. May 17, 2010 at 3:38 PM
    jmcnair327
    Baltimore
    05' Tacoma
    My satoshi turned out great you just have to get it to pull tightly against all edges, especially the bottom corners. Search and you will find several ways to do this.
  6. May 17, 2010 at 9:26 PM
    10PreRunner
    Kevin
    I kinda figured that it would have to be pulled tight on all the edges, especially in the middle where the deepest curve is. I have already fabbed up my grill to go in and was just curious how it would sit in there. Thanks for all the answers.
  7. May 17, 2010 at 9:28 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    mine sits flat cause i leveled out the inside of my grill when i did the fiberglass. I also used a material from custom car grills
