Quick question about what this means
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Isaiasgon, Apr 24, 2012.
  1. Apr 24, 2012 at 4:33 PM
    Isaiasgon
    Isaiasgon [OP] Well-Known Member
    GA
    2013 4x4 TRD Sport V6 DCLB
  2. Apr 24, 2012 at 4:34 PM
    trdNick
    trdNick Odie
    Texas
    07 Trd Off Road AC PreRunner Grocery Getter
    carrier bearing, levels your drive shaft and gets rid of take off shudder and other drive line vibes
  3. Apr 27, 2012 at 6:29 AM
    Isaiasgon
    GA
    Oh ok thank you. Do u guys know where I can get a good one?
  4. Apr 27, 2012 at 6:42 AM
    98regstick
    98regstick Well-Known Member
    Maryland
    '11 DCSB SR5
    OME 3" with 885s and top plate spacer, 2" AAL, OME rear shocks, Light Racing/SPC UCAs, OME CB Drop, 285/75/16 BFG AT's on Level 8 Guardian wheels
  5. Apr 27, 2012 at 6:49 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Do you have issues with vibrations? If not, don't mess with it...
  6. Apr 27, 2012 at 7:27 AM
    Isaiasgon
    GA
  7. Apr 27, 2012 at 7:29 AM
    Isaiasgon
    GA
    I do feel some vibrations in the steering wheel and stuff when I accelerate but never paid to much attention or though to much. Will that get rid of that kind of vibration or is it for more aggressive kind of vibration?
  8. Apr 27, 2012 at 7:32 AM
    Pugga
    Massachusetts
    F-150 Mod
    If it's through the steering wheel, it's most likely coming from the front end in which case this won't help. If vibes are felt in the floor boards or the seat, then it's probably coming from the rear in which case the CB drop kit might help some.
  9. Apr 27, 2012 at 7:43 AM
    Isaiasgon
    GA
    Interesting, brb I'm ganna go for a drive and see where exactly is the vibration coming from. :D
  10. Apr 27, 2012 at 7:30 PM
    Isaiasgon
    GA
    I think it's mainly on my gass pedal and my steering wheel and I also notice that when press on my brakes my streering wheel pulls to the right ALOT, any ideas on why it's doing that too...:confused:
    Ps: I just changed the break pads, rotors and both shoes.
  11. Apr 27, 2012 at 7:32 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Sounds like wheel balance or alignment
  12. Apr 27, 2012 at 7:34 PM
    Isaiasgon
    GA
    I've taken it to two different places twice and still the same, I guess I just got tired on paying $90ish for an illignment :(
  13. Apr 27, 2012 at 7:35 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    x2 That's what I was thinking. Steering wheel shake is usually due to out of balance tires or warped rotors or both together.
    I had to get new tires to get rid of my steering wheel shake. Between 55-65 it felt like I was riding in a blender.
  14. Apr 27, 2012 at 7:39 PM
    Isaiasgon
    GA
    Lol yea same here :D I'm going to get them re aligned then and check the tires. third time should be the charm then right lol :D
  15. Apr 27, 2012 at 7:42 PM
    NelsonTacoma
    Tucson, AZ
    Hopefully. Have you had your tires road force balanced? I did that when I balanced mine. Did it myself at work so it was free otherwise I wouldn't have.
    The only other thing I can think of for vibrations is a bent wheel. But that is the least likely scenario.
  16. Apr 27, 2012 at 7:45 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Can you please explain "road forced balance"?
  17. Apr 27, 2012 at 7:47 PM
    Isaiasgon
    GA
    Not to ask a dumb question but what's road force balance? I'm assuming it's not like a regular tire balance is it?
  18. Apr 27, 2012 at 7:52 PM
    NelsonTacoma
    Tucson, AZ
    You are correct. The road force balancer puts pressure on the tire tread with a roller (to simulate road pressure) and measures the balance that way. If the tire is too out of balance then the Tech will remount the tire on the rim, about 180 degrees from how it was before and recheck, until it has a better outcome. It's hard to explain, but if you watched it being done you could see what was going on.
    Edit: http://www.youtube.com/watch?v=efhgM2TcQpI
  19. Apr 27, 2012 at 7:56 PM
    Isaiasgon
    GA
    Oh ok well I'll give the alignment a try then the force road one and hope for the best...Thanks :D I just hope the vibration and the brake problem goes away :D
  20. Apr 27, 2012 at 8:10 PM
    babytruck
    NorCal
    Thanks for the info, Nelson.
