Quick question about wheel spacers...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MagneticTaco79, Jun 29, 2014.
  1. Jun 29, 2014 at 5:10 PM
    MagneticTaco79
    MagneticTaco79 [OP] COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    Hey guys getting ready to order these wheel spacers on Amazon Spidertrax Offroad WHS-007 SpiderTrax Wheel Spacers Toyota Hub Centric (Late Model) by Spidertrax http://www.amazon.com/dp/B009Y6PH2C/ref=cm_sw_r_udp_awd_6KkStb0MY4AQY
    Just wanted to make sure it's what I need to work properly on my truck with Method NV rims. They say "hub centric" Methods are not hub centric wheels. Does it mean the spacer is hub centric and works with any rim or does it mean it only works with hub centric rims? Hell I'm confused now. Lol
    Thanks for any help
  2. Jun 29, 2014 at 6:56 PM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    Any body?? I'd like to order these babies tonight!
  3. Jun 29, 2014 at 7:08 PM
    ailll1
    ailll1 Well-Known Member
    Alex
    Québec, Canada
    2016 Tacoma Trd Sport Double cab
    I'm pretty sure it will work with lug and hub centric. I've had my steelies (lug centric) and my stock TRD wheels (hub centric) both installed without any issues.
  4. Jun 29, 2014 at 7:11 PM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    Awesome! Thanks man. I can't see where they even offer a different type. I think it's the only ones they make for a Tacoma.
  5. Jan 30, 2020 at 7:39 PM
    Dmartin4
    Dmartin4 New Member
    Richard
    2014 Tacoma Limited
    Leveling lift with 275/65/18 tires
    I’m ready to install spacers on my 2014 prerunner with a leveling kit using 275/65/18 nitto tires on the original chrome wheels. My concern is are they safe they at hub centric 1.25” wide the tires are wheels fit just fine I have no rubbing anywhere just want to bring the wheels out a little for a tougher look
  6. Jan 30, 2020 at 9:23 PM
    DG92071
    DG92071 Well-Known Member
    Most of the spacers I've seen that are made for Tacomas had a hub bore of 106.1mm and are hub centric and are for hub centric wheels. Mine are 1.25", USA Adapters I think. I've used the brand before and they're great. A lot of people have successfully used Spidertrax and Borla. As far as being safe, they are safe if you take the time to properly retorque them after 100 miles and you should also consider your intended use of the truck. If you're going to bomb the truck offroad you might consider staying away from wheel spacers. Mine is a mall crawler.
    badger likes this.
  7. Jan 31, 2020 at 4:25 AM
    badger
    badger Well-Known Member
    07 SR5
    Like most things, wheel spacers are fine if used with some sanity. I've wheeled my truck pretty hard over 100,000 miles with 1" spacers, but I also run factory 7" wheels and skinny tires. My tire/wheel combination weighs just 72lbs. Combining spacers with wide or offset wheels magnifies the stress. As DG said, you need to consider how you drive. You can get away with more if the truck is mostly street driven. If you drive like a retard offroad, I wouldn't recommend them.
    whatstcp and DG92071 like this.
  8. Jan 31, 2020 at 4:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's safe to say that spacers are a bandaid for a wheel (or maybe tire choice) that don't have the correct fitment.
  9. Jan 31, 2020 at 4:47 AM
    badger
    07 SR5
    It can be. I run minimal spacers for two reasons. Tacomas have no clearance for the use of chains, and I want to run chains. The skinny tires I run have a pretty narrow track, so the spacers give back a little stability in off camber conditions. If I could buy a quality wheel with the right offset, I would, but guys like me who want skinny tires on skinny wheels have zero choices. I bought my spacers from All-Pro many years ago. I don't know who makes their spacers, but they have held up very well.
  10. Jan 31, 2020 at 4:49 AM
    badger
    07 SR5
    The vast majority of people are far more concerned with cosmetic preference than anything remotely related to function. That drives the market.
  11. Jan 31, 2020 at 8:16 AM
    Taco'09
    Taco'09 Well-Known Member
    Same deal here. For where I live chains are essential on all 4 and even the Class 'S' are a problem up front on stock trucks and trucks with mild lifts. Despite most of my comments on spacers I now have 0.75" Bora on mine now and use the RUD 4X4 chains. Also running thin 17" tires. Not real happy with the Duratracs in snow so need to probably go back to a dedicated winter set. @badger what tires you running in the winter?
  12. Jan 31, 2020 at 10:33 AM
    badger
    07 SR5
    I lived in the Northwest for over 30 years, so snow and ice are my old friends. I sipe all my tires. Normally I sipe all the interior blocks approximately 3/8" apart and leave the outer blocks unsiped for resistance to chunking. Siping makes a big difference. One tire that has proven itself to me on ice and snow without any modification is the Yokohama A/T G015. Really great tire for those who deal with a lot of ice, but still want a good general use A/T.
    Razor siping is much better than a burner, or even factory siping in my experience. The sharp edges created by the razor really bite and they are essentially self sharpening as the tire wears. I've not had great luck with Goodyear products on ice. Mostly I stick to Cooper tires. They are sold under MANY brand names like Dick Cepek, Dean, Mickey Thompson, and Mastercraft to name a few. I am currently running Cepek Extreme's with center siping. I have my own razor siping tool.
  13. Feb 1, 2020 at 8:49 AM
    Taco'09
    @badger
    I purchased the razor siping tool -- the heated one -- where you can add from 1-4 blades, and even then it is quite a workout. You are correct though, siping makes a huge difference.
    Long time ago I did find the perfect year-around tire that was really aggressive in deep snow but alas, it has been discontinued....
    I also sought out one of the Cooper's three years back and liked the fact they tend to be light weight, and actually purchased their latest-hyped all season greatest-in-the-snow tire according to all the "experts" but was sorely disappointed. It also did not last very long in the market and appears to have now been discontinued.
  14. Feb 1, 2020 at 9:22 AM
    badger
    07 SR5
    Yeah, hand siping is a workout. Sorry your Coopers didn't work out. I've run Deans, Coopers, Mastercrafts, and Cepeks, all with good luck. None were super long wearing, but they performed well. My Cepeks are the lightest E rated tires I have found. They are a ful 12 pounds lighter than my Cooper ST Maxx in the same size. Try the G015s. I know a few people including myself running them on various vehicles with good results. I just had my Suzuki on ice last weekend and I was able to get up hills in 2wd, that really surprised me.
  15. Feb 1, 2020 at 2:00 PM
    Taco'09
    Thanks for these comments. I think I will try the G015s. It just gets real expensive trying different tires and I have to make up new excuses to the spouse as to why I got yet another set of new tires....
  16. Feb 1, 2020 at 3:13 PM
    badger
    07 SR5
    Understood! Don't take my word for it. Ask around. I use them and I have a friend in Pennsylvania with a Subaru who swears by them. I also have a friend who is a lead guy at Discount Tire who runs them on his Gen 1. This is the basis for my comments.
  17. Feb 15, 2020 at 6:42 PM
    K-DubTaco
    K-DubTaco Well-Known Member
    Ken
    VB
    ‘25 TRD Off Road
    What kind of leveling kit are you looking at running? How much lift do you want?
  18. Feb 16, 2020 at 9:59 AM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    I also have the g015 and have been thoroughly impressed in the snow and ice. That said, will probably go with duratracs on my next set, the yokos aren’t quite as heavy duty as I’d like
  19. Feb 16, 2020 at 10:05 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I hear these are bad for wheel bearings
  20. Feb 16, 2020 at 11:53 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    They put a bit more strain on the wheel bearing but I don't think it's fair to say adapters are 'bad' for wheel bearings. It's a trade-off that the customer makes. There are other potential issues. See Jason's video below. As I recall, you'll need longer wheel studs to properly fit the adapters. You want the adapter nuts to fully engage on the truck's wheel studs. And you may need to trim them of the aftermarket studs stick out of the adapter too much and the aftermarket wheels you get don't have indentations for the studs to sit in.
    All this being said, I drove with 1-inch wheel adapters from IchibaUSA for about three years; I off-roaded in them and never had any issues.
    https://www.youtube.com/watch?v=hWijfooeSyU
