Quick question about windows 7 install
Discussion in 'Technology' started by Tylerm5000, Jan 1, 2012.
  1. Jan 1, 2012 at 2:23 PM
    Tylerm5000
    Tylerm5000 [OP] Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Hello all,
    I am going to be building a new computer in the next few weeks. I have a Windows 7 x64bit upgrade CD. I was able to use it to re-install a clean copy of 7 on my new SSD but it won't accept the product key so I am running it off the CD for now. I am assuming this is due the clean install not being an upgrade. I thought an upgrade CD wouldn't give me the option of a clean install without an old OS installed. Anyway, the new computer will be a similar situation and I don't want to buy another copy of Windows 7; especially since 8 is around the corner.
    I do have a copy of Windows XP pro 32 bit.
    Can I install the XP and then upgrade it back to Windows 7?
  2. Jan 1, 2012 at 2:27 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    That is what I would do.
  3. Jan 1, 2012 at 2:29 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    You can't upgrade a 32 bit OS to a 64 bit OS. Has that copy been installed before? If you changed any hardware that is why it won't take. The product key binds itself with your hardware.
  4. Jan 1, 2012 at 2:33 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Always AVOID these upgrade versions.
    You might be able to call Microsoft, plead ignorance and get an activation key.
  5. Jan 1, 2012 at 2:45 PM
    tbturner47
    Not always, just pay attention to small details. I'm NOT:rolleyes: running a Windows 7 upgrade as a full install;).
    There's always a way..
    And while everyone says sometimes MS gives out activation codes if you cry about it, in the last 10 years I've been working on computers I haven't received one in at least 6 years.
    With some more details I could possibly help you out.
  6. Jan 1, 2012 at 7:29 PM
    jflan
    Vancouver, WA
    Yes always ;)
    Go OEM (for probably less cost) or Full
    OEM is essentially Full without the retail box.
    Even the basic concept of "Upgrade Version" is flawed. Don't buy it.
    OP, there has been a couple of times where I had to call Microsoft during installs for various reasons.
    They will typically ask you a few questions (anti-piracy stuff) and if they're convinced you're legit, they will give you an Activation Key over the phone, which is different than you Product Key.
  7. Jan 1, 2012 at 10:12 PM
    Tylerm5000
    Tyler
    Oregon
    Thanks guys. Excellent replies I really appreciate it. I'll just pick up a copy of Windows 7 full x64 and call it good. At least I have my old computer running for now.
  8. Jan 2, 2012 at 2:23 AM
    tbturner47
    Students can get discounted copies of upgrade versions for around $60. I have one. Clean install and running for 2 years. It's not flawed, the software piracy laws are flawed.
    OP if you wanna save some coin pm me.
  9. Jan 2, 2012 at 3:01 AM
    jflan
    Vancouver, WA
    I would buy an OEM version. It's generally not marketed to the public as it is intended for system builders and administrators.
    It is a Full version without the retail box at bulk pricing.
    http://www.newegg.com/Store/SubCategory.aspx?SubCategory=368&name=Operating-Systems
    Edit:
    If I had a legit Key I would still call as a last resort before buying another copy.
  10. Jan 2, 2012 at 3:09 AM
    jflan
    Vancouver, WA
    Dood, if your admin is peddling upgrade versions, then he/she is a n00b.
    The M$ planet runs on OEM whether it's gang-installed over a network or individually installed.
    Upgrade and OEM pricing is similar with OEM usually cheaper.
    Out.
  11. Jan 2, 2012 at 3:26 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I bought the Upgrade for 79 bux and IIRC I did used a generic Vista key or something to that extent. I did a clean install as well. Its not hard, but its not legal without a Vista key.
  12. Jan 2, 2012 at 9:43 AM
    tbturner47
    What are you talking about?
    First off, were talking about personal computers, not company ones. Second, regardless of whether it says upgrade, oem, or retail they are all still full versions.
    An upgrade simply provides you with the option to install inside a Windows environment without erasing your data.
    And as I stated above students can get the upgrade version cheaper than an oem.
  13. Jan 2, 2012 at 9:45 AM
    jflan
    Vancouver, WA
    Nvrmnd
  14. Jan 2, 2012 at 2:18 PM
    Tylerm5000
    Tyler
    Oregon
    Thanks guys I appreciate it. I am a little rusty. It's difficult to tend to all of my interests at once and be 100% or even 50% competent in them. Nursing and EMT have total priority right now so my computer knowledge is having to be brushed up. I appreciate the help.
