Quick question: SAWs coilover spacers.
Discussion in 'Suspension' started by ldanny, May 14, 2009.
  1. May 14, 2009 at 3:35 PM
    ldanny
    ldanny [OP] Well-Known Member
    I'm going to install my coilovers, but is the bigger part of the spacer suppose to go in the front or back? Thanks.
  2. May 14, 2009 at 3:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Larger part goes to the rear.
  3. May 14, 2009 at 3:56 PM
    ldanny
    thanks.. im going to start it the install wish me luck.. :D
  4. May 14, 2009 at 4:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its easy.....post up some pics when its done.:)
  5. May 14, 2009 at 5:15 PM
    ldanny
    hey are you sure its to the rear? I just found the instructions on the SAWs website, it says larger to the front.. just want to double check
  6. May 14, 2009 at 5:20 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    this must be new...my SAWs dont have that...theyre even on both sides
  7. May 14, 2009 at 5:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :annoyed:
    I had it backwards!! Sorry...:eek:
  8. May 14, 2009 at 5:30 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    mine to, sure they are saw's, not some chinese knock off. j/k:D
  9. May 14, 2009 at 10:19 PM
    ldanny
    man.. that took a good 3 hrs... the stupid bolt on the top mount snapped... and then the tie rod kept on spinning, then i figured that you have to hammer it back in but there was grease so it kept spinning...
  10. May 14, 2009 at 10:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You could have held the tie rod with a 6mm hex wrench while you tighten it down with a box wrench....
