Quick Question: Time for 4x4 to engage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wh013mi1k, Nov 8, 2012.
  1. Nov 8, 2012 at 9:15 AM
    wh013mi1k
    wh013mi1k [OP] Well-Known Member
    2012 DCLB TRD SPT V6
    Just need some insight so I can pretend to know what I'm talking about to my wife...
    Last night we finally used the 4x4 in our new 2012 Tacoma (auto tran) and she asked a question that I couldn't answer. She noticed that when we engaged 4x4 while traveling ~40mph it took about 8 secs to engage; when we engaged 4x4 while traveling between 10-20mph it only took about 3 seconds to engage. Then I noticed that if I engage it while completely stopped - it won't engage at all until I start moving forward...
    Why does the time for 4x4 to engage vary depending on the speed of travel? So in my experience if I'm rolling at 40 mph it takes 8 seconds for it to engage, less than 20 mph it takes 3 seconds, and if at a stop it won't engage at all until you move forward. Why is that?
    Everyone should remember from my previous thread that I'm mechanically retarded so I have to ask basic questions. But this is how I learn. Thanks everyone for any insights.
  2. Nov 8, 2012 at 9:19 AM
    la0d0g
    running for the hills
    For crawling not hauling
    Whats the question?
  3. Nov 8, 2012 at 9:25 AM
    wh013mi1k
    Sorry about that - edited.
  4. Nov 8, 2012 at 9:31 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    It takes a slight delay for the synchros to mesh together. When you're stopped completely, they're not moving at all, so if they're not lined up properly, they won't line up at all until you start rolling ahead. And it takes longer the faster you go (generally speaking) because the gears are spinning faster.
    The best case that I have found to engage it, it when rolling slowly (1st gear since I'm a manual) without having my foot on the gas pedal. You may notice when you engage 4wd with your foot on the gas, that the truck lurches a bit. Taking your foot off the gas minimizes this.
    This delay is why you need to be thinking well ahead of what you're actually doing. Observing the road well ahead, and thinking "Okay, in 500m, 1 km, 1 mile, whatever, I will probably need my 4wd. I should engage it now."
  5. Nov 8, 2012 at 11:22 AM
    BlackSeven
    BlackSeven Well-Known Member
    Maryland
    2017 4cyl 5 spd 4x4 extended cab
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    Exactly. The solenoid that pushes the gear over to engage the front axle is waiting for a "no load" or "Light load" Situation. I don't believe there is any synchronizer on that gear (There wasn't when I swapped my front axle gear for 4.88's) Take your foot off the gas while the truck is rolling forward and wait for the 4WD light to stop blinking. It's the least stressful, and fastest way of engaging 4wd on our trucks.
  6. Nov 8, 2012 at 11:27 AM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    My terminology might be a bit off :p
  7. Nov 8, 2012 at 11:34 AM
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    Thanks for asking a question that i've been wondering too. good stuff to know!
  8. Nov 8, 2012 at 12:27 PM
    wh013mi1k
    This is great detail - thanks! Why in some cases can it take almost 10 seconds when traveling at a constant speed (40)? It seems a little long; but again, I know nothing about mechanics and am just speaking out of my @$$.
  9. Nov 8, 2012 at 1:36 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The front diff disconnect has to lock, and the xfer case has to shift. When travelling, you have to be going straight for the front diff to lock faster. It also becomes quicker the more often you use it.
    Make sure you use it for 10 miles per month, off pavement, to keep is working properly.
  10. Nov 9, 2012 at 12:24 PM
    thatguy0o0
    thatguy0o0 trunk monkey
    Rapid City SD
    White '13 TRD Sport.
    Awesome. I was always a little worried about engaging it at speeds around 40 didn't know if it was good for the components and what not. Now I know that and then some thanks for the advice and for asking the question.
