Quick question with anyone below zero temps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gabtap, Jan 7, 2017.
  1. Jan 7, 2017 at 4:26 PM
    Gabtap
    Gabtap [OP] Well-Known Member
    2017 Black Offroad
    First time we hit below 0 (32F) this year, anyway I just tried to run my wiper blades and my passenger blade isn't touching down in the middle has anyone else had this issue, I sprayed the windshield with fluid and the blades clean the driver side and half of the passenger, theres a huge puddle of fluid in the middle that the wiper is doing nothing to. I checked the wiper and it's not frozen, it's not making contact for some reason. Think I should make Toyota replace the wiper :goingcrazy:
  2. Jan 7, 2017 at 4:31 PM
    PeteK
    PeteK Well-Known Member
    Brockton, MA
    2017 Cement Truck
    You mean below 32? There is frozenness stuck to it. Run the defrost on high for a bit and it'll melt and be normal.
  3. Jan 7, 2017 at 4:33 PM
    PeteK
    Brockton, MA
    2017 Cement Truck
    Or upgrade to a Pro and get heated wipers. :eek:
  4. Jan 7, 2017 at 4:34 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If you are certain the rubber wiper blade is not frozen, check the guides to make sure the blade not binding in the tracks.
  5. Jan 7, 2017 at 4:41 PM
    Gabtap
    2017 Black Offroad
    0 degrees Celsius is 32F lol but yes below 32 Not possible, I ran the the truck for 30 mins with defroster on high the whole ride truck was full operating temp, still did it, also manually inspected wipers and theres no ice on them.
  6. Jan 7, 2017 at 4:41 PM
    Gabtap
    2017 Black Offroad
    Positive, I checked with my light and with my fingers and it's all malleable
  7. Jan 7, 2017 at 5:23 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    That just happened to me yesterday.... I brought the wiper blade in the house and ran hot water on it.... left it to dry overnite... good to go today..
    It was a little bit of ice on the blade joints.... ALSO... spray some silicone on the arm where it swivels when you pull the blade away from the window...
    Worked for me....and it was -14 Celsius today...
    Mush Mouse likes this.
  8. Jan 7, 2017 at 5:25 PM
    Gabtap
    2017 Black Offroad
    Will try that tomorrow after work, thanks
  9. Jan 7, 2017 at 6:18 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Only going to 8 tonight, so I can't help.
    G.
  10. Jan 7, 2017 at 6:23 PM
    Optimaltaco
    Optimaltaco Well-Known Member
    Dave
    Cochrane, AB
    '17 Tacoma DCSB TRD Off-Road
    TRD Pro - Grill and Rear Tail-Lights OEM Roof Rack FN overland 17x8.5” -6 BFG KO2 Morimoto 2 stroke LED headlights 30” auxbeam light bar Custom built Canopy Readylift 3" spacer kit Deaver 1.5-2" AAL Amber hazard strobe lighting
    Usually runing some washer fluid for lower temp weather helps with any de-icing but it's hard to say. Right Now it's -16C and I'm not having any issues but in the morning usually if the blade has ice on it a few presses of the washer fluid and defrost in high will get rid of it pretty quickly.
